[Gen4] Attempted theft - Kawasaki ZX-10R.net
 6Likes
  • 1 Post By scout
  • 1 Post By Porschenut
  • 2 Post By JayBoCC2
  • 1 Post By obijack
post #1 of 7 Old 09-30-2017, 10:52 PM Thread Starter
It makes my blood boil! I came out of work at about 7pm, in Cupertino, CA, and in-bred moron has only tried to pry the ignition barrel away from the steering stem, making a right mess! Smashing the metal ring, that goes around the ignition, to pieces, and demolishing the plastic shield that slides over the ignition barrel in the process. Urgh!
Thoroughly pissed off! :-( Anyway, I?ve remove my top triple clamp and drilled the security bolts out ready to get a new top tripple. Just considering a new lock set to replace the now half demolished ignition.
I have this sneaky feeling this was attempt 2. About 4 weeks ago, I arrived at work and took my helmet off to check my rear tire wear. Was bent down examining it for a short while before deciding new tires needed. That afternoon when I got back to my bike, I had a flat rear! When repairing it, on site at work, the leak was that bad it was clear to hear with air in the tire! A major leak! Funny how I didn?t hear it in the am? I wonder if that was done in the hope I would leave it at work over night?
Now I need a proximity sensor alarm for my ride maybe? Any recommendations? My bike is clearly a marked bike now! Down-side, if I got an alert it would take me a while to descend 6 floors to the underground parking garage.
Thanks
Rob
trebor27 is offline
post #2 of 7 Old 10-01-2017, 07:54 PM
The Pace
scout's Avatar
You must park inside a secure garage or apartment. Then you will have some peace.
trebor27 likes this.
scout is offline
post #3 of 7 Old 10-02-2017, 12:58 PM
Porschenut's Avatar
Sounds to me like your particular thief doesn't have the means to haul the bike away but only to try and ride it away. For a cheap and instance solution buy 2 brake rotor locks and always lock up both wheels. He's only going to get the bike if he can haul it away and that requires a couple guys and a stolen van.
Porschenut is offline
post #4 of 7 Old 10-02-2017, 12:59 PM
Porschenut's Avatar
Or you could go overboard like I do and have a motion sensing alarm and 2 disk locks. Triple deterrent.
post #5 of 7 Old 10-02-2017, 05:14 PM
You can keep your bike in my back yard in sunnyvale. lol
trebor27 and evilaugust like this.
JayBoCC2 is offline
post #6 of 7 Old 10-02-2017, 06:16 PM
Best thing you can do is have Comprehensive insurance and anchor your bike to the concrete with something like this:
Kryptonite Stronghold Ground Anchor Lock | Chain Reaction Cycles
2016 Kawasaki ZX10R KRT ABS
2016 Suzuki GSX-S 1000 ABS
obijack is offline
post #7 of 7 Old 10-09-2017, 09:50 AM Thread Starter
Thanks for all the replies!
Iím harassing the building management to have some motorcycle security installed. Iím hoping they will install some ground anchors, I already have a beast of an English Chain, and lock. And I was wondering about buying a Xena alarm disc lock to go on the rear disc too.
Together they could be as good as I can get I guess.
I need to chase them up today, as usual, they do nothing unless hounded!
Rob
trebor27 is offline
