Factory second 1/5th - Page 2 - Kawasaki ZX-10R.net
post #11 of 13 Old 04-01-2015, 10:29 AM
Arnbo's Avatar
Originally Posted by Arnbo View Post
I have a friend who recommends the yamaha R6 throttle kit
says it fits better?Or works better? Anyone know?
Riflemans seem like the popular way to go.
Which is the Best?
I guess I will order the yamaha R6 since noone wants to add info
Arnbo is offline
post #12 of 13 Old 06-26-2016, 10:52 AM
Im trying to get hold of him now to purchase another one i dont think r6 will work as the 1/5 is the largest fit on the standard housing
maisonstorm11 is offline
post #13 of 13 Old 09-23-2016, 10:30 AM Thread Starter
Of course you are faster
Rifleman's Avatar
Which is the Best?
can't believe I missed this.
yes, the R6 tube will give you a better throttle response then the OEM grip...
however...
1. it's not a full 1/5th (72' degrees rotation) it's more like 80' - 82', so better, but not what it could be.
2. the R6 tube is about 3/8ths of an inch shorter, so you get a gap between the end of the clip on weight, and the throttle tube.
3. The rubber pattern doesn't match.
all the above are not show stoppers, just things that I have noticed. If you have a track dedicated bike, and you don't care if the grip is a little short, different rubber, etc. and you are on a tight budget, that R6 tube is a quick inexpensive ($15 - $25 on Ebay, depending on age and damage) way to go.
if you want your bike to retain the original OEM look but give you a 20% improvement in throttle response, the 1/5th insert is the way to go.
Need to know how to install your Rifleman's 1/5th throttle insert? click me
For more info on a sticky grip (not enough cable slack) click me
And another amazing install write up click this
Originally Posted by Rifleman View Post
lol, once you go 1/5th... you NEVER go back
Rifleman is offline
