How Do You Check A Motorcycle’s Oil Level? - Kawasaki
  • 1 Post By
post #1 of 2 Old 09-02-2016, 08:22 AM Thread Starter
Editorial Content
Modern motorcycles are incredibly reliable, but they still require you to check a few things in order to keep them running at full potential. The engine oil is one of those items you should never neglect. After all, you don’t want to run your high-revving, manufactured-to-aerospace-tolerances, and extremely-expensive-to-replace engine without the proper lubricant, do you? Additionally, an engine’s oil can reveal a good bit of information about the condition of its internals to even a novice mechanic armed with a little information.
To actually check an engine’s oil level, take a look at its owner’s manual. Seriously, it’ll outline the specifics that the manufacturer recommends – and they do vary slightly from bike-to-bike. Still, the steps do follow a rough pattern.
Make sure the engine is warmed to operating temperature. After turning it off, allow the oil to drain down from the top end by waiting a few minutes. Bikes with a sight glass require that you hold the bike level – either from the saddle or beside the bike – look at the window conveniently located on the bottom of the engine to make sure the oil level is between the two marks on the case. (Tip: If your bike has both a centerstand and a sight glass, measure it the above way and then compare it to the level shown while on the centerstand. This way you can use that level as reference so can check the oil level when it’s parked on the centerstand in your garage.)
For engines with a dipstick, check your owner’s manual to make certain how the stick is to be inserted for an accurate reading. Usually, you will wipe the stick and insert it into the case until it makes contact with the filler plug’s threads. Be sure the plug is straight and the bike is level or you may get an inaccurate reading.
If you ride your bike regularly, you should check its oil at least weekly. If you ride infrequently, consider checking before every ride. With regular checks, you are more likely to notice symptoms of little problems before they get bigger.
Read more about How Do You Check A Motorcycle’s Oil Level? at
ana likes this. is offline
post #2 of 2 Old 09-17-2016, 07:41 PM
The Pace
scout's Avatar
I was told by most that we have to change the oil. Check it or change it is the question.
edit recorded on 09.21.16. I changed my oil yesterday. Reason was because of unplanned down time. Dealer intalled motul whatever with their filter at about 40,500 miles on June 21, 2016. The 2013 g4 now has over 57,500 miles on it or right around that number. The motul oil worked fine but often clunked gears from the beginning of motul up to the end.
I had the bike on the rear stand and removed the oil plug. Plug was clean. Drained oil. Removed the filter which was not easy. Cleaned filter area and installed new amsoil filter. Loaded amsoil. Ran bike. Turned off bike and came back a few hours later and added more oil 'cause the window said low. Ran bike and came back next day and all looked good in the land of the oil window!
scout is offline
In order to be able to post messages on the Kawasaki forums, you must first register.
