Do I Really Have To Change My Oil Every Year? - Kawasaki ZX-10R.net
 7Likes
  • 3 Post By tdh
  • 1 Post By scout
  • 1 Post By MrMoto73
  • 1 Post By banzai
  • 1 Post By scout
post #1 of 10 Old 03-01-2017, 03:38 PM Thread Starter
Editorial Content
Dear MOby,
I just saw your answer regards oil change. My manual says that I need to change oil every 3000 miles. But I only ride about 1000 miles per year (very short commute). By the book, I need to perform oil change every three years. Do I really need to change oil every year? Is it okay to change oil every three years, just because I donít ride that much?
Thank you
Jay
PS: Just to make myself comfortable, I do oil change once a year.
Read more about Do I Really Have To Change My Oil Every Year? at Motorcycle.com.
motorcycle.com is offline
post #2 of 10 Old 03-01-2017, 04:35 PM
tdh
tdh's Avatar
Actually our manual says every 7500. But, I would wait for scout's opinion on this one. :)
swopesy, LDH and Kllongbrake like this.
tdh is offline
post #3 of 10 Old 03-02-2017, 12:44 AM
My ZX-10R manual says every 12,000 kms (assuming I'm reading it correctly.)
deuterium_knight is offline
post #4 of 10 Old 03-02-2017, 05:33 AM
Depends on usage
At one extreme, if you use the bike for short hop journeys regularly, I believe the heating / cooling cycle will introduce condensation moisture into the oil much more readily than longer journeys. This moisture will reduce the effectiveness of the oil.
At the other extreme, if you are doing a lot of performance related activities such as track days, drag racing etc. These put a big strain on the oil and again quickly reduces it's performance.
Either end of the scale, I'd probably change oil quite frequently...Every third track day....Every quarter for short hop use.
Otherwise, stick to the service interval and use a high quality semi synthetic (I use ester based synthetic for track).
Hope that helps.
10Arghh is offline
post #5 of 10 Old 03-05-2017, 04:11 PM
The Pace
scout's Avatar
Look at the clean oil in the photo. No way that needs changing. Case closed!
belkins likes this.
scout is offline
post #6 of 10 Old 03-05-2017, 05:44 PM
Kawasaki Whisperer
MrMoto73's Avatar
Send a message via MSN to MrMoto73
AMSOIL and done for life.... right scout?
scout likes this.
I DON"T HAZ ANY SNYDER PROBLEMS
MrMoto73 is offline
post #7 of 10 Old 03-18-2017, 06:34 PM
The Pace
scout's Avatar
Originally Posted by 10Arghh View Post
Depends on usage
Hope that helps.
True, but track days don't pressure the bike at all for normal track guys. Pros are a bit different but not that much, imo.
scout is offline
post #8 of 10 Old 03-29-2017, 02:35 PM
banzai's Avatar
I used Mobil 1 MX4T for a few years. But after having to go to 3 Auto Zones to find 4 quarts of it I switched to Amsoil. Buy a twelve pack and good for year or two. On my ZX-10R I noticed at around 4K miles on the oil, shifting resistance starts to build up requiring just a little bit more pressure on the shifter to shift gears. That and milage is usually my signal its time for an oil change.
Since I live in Texas, I can ride almost year round. If I was up north I would change my oil and filter at the end of the riding season so the motor has fresh oil and the fuel tank is full with fresh fuel and Sta-Bil.
When Spring arrives, the bike is serviced and ready to go.
You can always send oil sample off for testing to determine if it is working and to see what contaminants are in the oil.
mpp12 likes this.
'04 Blue ZX-10R, FORKS: Race Tech Gold Valves, .85 KG/mm springs, US1 suspension fluid, Shock: Penske 8900 shock w/8760 compression adjuster, Gilles rear sets and levers, Scotts steering damper, Racefit Mega slip on, Zero Gravity screen, ZX636 Master Cylinder, Galfer Superbike braided brake lines, Vesrah SRJL17 pads, Kawasaki seat cowl, undertail kit, Oury Grips, Valentine One radar detector with Legal Speeding heads-up helmet LED.
banzai is offline
post #9 of 10 Old 03-29-2017, 03:16 PM
mpp12's Avatar
here in the island... we drive hard and all year around... every 4K new oil and filter... sometimes just new oil and filter one every 2 changes..
mpp12 is offline
post #10 of 10 Old 04-10-2017, 08:40 PM
The Pace
scout's Avatar
My case of amsoil arrived today. But I usually use it for the cages. Trouble is that I also bought two filters for the 10r. Wasn't thinking.
tdh likes this.
scout is offline
