Gen 5 stock wheelbase 9.52@152mph - Kawasaki ZX-10R.net
 6Likes
post #1 of 13 Old 08-20-2016, 04:41 PM Thread Starter
GSX-R//Iceland's Avatar
Went to a test and tune today and ran a couple of 9.5s on my stock wheelbase 2016 zx10r.
Pump gas and I weigh 210 lbs
ID:	380953   Click image for larger version
ID:	380961   Click image for larger version
ID:	380969   Click image for larger version
theatiss, turtle1000 and Mach.81 like this.
GSX-R//Iceland is offline
post #2 of 13 Old 08-21-2016, 02:36 AM
Well done. Thats quick. What mods have you done to it and did you do it with electronics deactivated?
ukzx10r is offline
post #3 of 13 Old 08-22-2016, 11:41 AM
nakedinseattle's Avatar
right on man thats damn good!
Shut up and ride.
Nun sacciu, nun vidi, nun ceru e si ceru durmiv
nakedinseattle is offline
post #4 of 13 Old 08-22-2016, 02:34 PM
ShawnG's Avatar
that is very fast for stock wheel base and stock ride height, doesn't look like you had the front strapped on the action shots. The best i could get my 4th gen was 10.3 stock wheelbase and hieght, ecu flash/slip on and gearing. Couldn't keep the front end down for the life of me curious if you were running with tc on and if so what setting worked best for you? went through a clutch in one day too trying to get a good launch.
ShawnG is offline
post #5 of 13 Old 08-22-2016, 03:17 PM
Did you use launch control? If not, why not? Did you try it?
2016 Kawasaki ZX10R KRT ABS
2016 Suzuki GSX-S 1000 ABS
obijack is offline
post #6 of 13 Old 08-22-2016, 05:53 PM Thread Starter
Thx , Graves exhaust , Woolich flash, Sprint PO8 airfilter, 520 chain Conversion 16/40
Everything off
The bike was strapped when i ran 9.52, but i went 9.7 with no strap. No tc , everything off
I also went through my stock clutch after like 6 runs , but i changed the Gearing and went with cycleconcepts Drag pak clutch (backdated gen 1 with a judder plate) works way better
I did not, i have tried it and i dont like it, always went slower
theatiss likes this.
post #7 of 13 Old 09-04-2016, 01:53 AM
Joyridn's Avatar
what kind of power is your gen 5 making after your flash?
Joyridn is offline
post #8 of 13 Old 09-04-2016, 03:10 PM Thread Starter
Not sure , hasnt been on a dyno yet
post #9 of 13 Old 12-21-2016, 02:10 PM Thread Starter
Two more pictures
ID:	388433   Click image for larger version
post #10 of 13 Old 03-06-2017, 03:45 AM
Nfamous60's Avatar
Your not using the launch control either??
Nfamous60 is offline
