Engine overhaul - Kawasaki ZX-10R.net
 4Likes
post #1 of 12 Old 12-04-2017, 07:19 PM Thread Starter
Engine overhaul
I just did 2 race seasons with my 16 Zx10, about 5000 track/race miles. The motor is still very strong, I don't think there has been any drop of performance, at least my lap times don't say so.
Should I jump on a 3rd season or rebuild the motor? Any of you guys have experience with that many track miles and how well these motors hold up?
cca101 is offline
post #2 of 12 Old 12-04-2017, 08:08 PM
Victors's Avatar
5th gen should last longer than the previous gens. I'd keep it going.
2013 10R
2007 650R
2016 10R
Victors is offline
post #3 of 12 Old 12-04-2017, 09:07 PM
thundercoupe9's Avatar
It's cheaper to check and replace worn out parts now than after the engine blows up regardless what gen the bike is.
evallarta1 likes this.
thundercoupe9 is offline
post #4 of 12 Old 12-05-2017, 08:07 AM
gaz
i would run a couple of tests to verify engine condition/performance. pull the oil pan to check for any bearing material, always a good thing to do anyway to clean out any clutch material. check compression balance, and leakdown test to check ring/valve seal. all within limits, go racing with confidence.
gaz is offline
post #5 of 12 Old 12-05-2017, 09:44 AM
dricked's Avatar
My gen 4 at 4,000km needed all new valves. There’s no warning, the top end will all of a sudden sound like shit.
My rebuild schedule is bottom end every two years and top end every two years alternating so it’s not one big bill at once. Stretching it out until failure will result in a single very large repair bill. Good luck.
dricked is offline
post #6 of 12 Old 12-05-2017, 12:07 PM Thread Starter
Cool thanks guys, sounds like I'm going to pull this engine apart and just do it. The only thing now stopping me now is Kawasaki won't pay out anymore because its a 2016 and I need a 17 or newer. Considering I podium almost every race the contingency pays for pretty much all my racing fees/tires. Decisions....
cca101 is offline
post #7 of 12 Old 12-06-2017, 10:12 PM
Newf's Avatar
Originally Posted by dricked View Post
My gen 4 at 4,000km needed all new valves. Thereís no warning, the top end will all of a sudden sound like shit.
My rebuild schedule is bottom end every two years and top end every two years alternating so itís not one big bill at once. Stretching it out until failure will result in a single very large repair bill. Good luck.
I plan to do a full rebuild on my zx10rr at about 4000km, the Thai Kawasaki Sbk team changes valves every 2000km.
If you keep the engine completely stock then they seem to last pretty good but once you add a little extra (race cams) then they donít hold up so well. My teammates just had to have their BSB spec engines completely rebuilt, one lasted just over 4000km and the other bent a valve just under 4000km.
Newf is offline
post #8 of 12 Old 12-07-2017, 12:19 PM Thread Starter
Wow, so shimming the valves isn't enough, actually need to replace the valves completely?
cca101 is offline
post #9 of 12 Old 12-07-2017, 05:25 PM
I put on 12k race miles on my gen4. Checked the valves replaced clutches, frequent oil changes. Still runs fine. No engine mods. Just kit ECU and a good map.
gaz likes this.
Lanister is offline
post #10 of 12 Old 12-07-2017, 08:56 PM
Newf's Avatar
If it just a bike you use on the road and occasional trackday then no but these are racebikes only I’m talking about. One of the top Superstock racers here has 2 full race seasons on his but we’re not sure what was serviced on it during the first year as it was Kawasaki Thailand Superstock Bike. But most guys are doing preventative maintenance and 4-6000km rebuilds.
The top Superbike guys are running under 3s off Rea’s best race lap and Superstock are about 4-6s, so the pace is pretty quick.
For comparison the Yamaha Thailand Team changed atleast 2 new engines in their Superstock R1 this year and even more last year. Last year they had issues with bent valve on the stocker and Sbk engines, which is why they’ve upgraded the valve springs on the 2017 R1.
I'll ask the Thai mechanics why they change the valves so quickly cause it does sound to quick to me, personally i probably wouldn't change the valves until the 2nd rebuild at about 8-10,000km. On the S1000rr HP kit 1 engines they recommend new valves at 18,000km.
Newf is offline
