ECU poping fuse - Kawasaki ZX-10R.net
 2Likes
  • 1 Post By SkyDork
  • 1 Post By nakedinseattle
post #1 of 6 Old 07-24-2017, 11:45 PM Thread Starter
Frerichs14's Avatar
ECU poping fuse
07 ZX10R
i bought the bike a couple weeks ago first ninja when i was riding it home the battery got hot and lost power.
when i got it home and everything cooled down cause it was a very hot day that day i put in a new batt to see where i was at with the bike and do some tests i couldn't find anything other than the following that i replaced>> but when i put in the new batt it popped the ecu fuse
the stator was out>>> I mean out it was demagnetized!!! fell off in my hand it was replaced
rectifier was burnt out i replaced it
i also replaced the entire wiring harness just in case something broke in the harness and was grounded
i put everything back together along with a fresh oil change just because and as soon as i hook up the batt it pops the ECU fuse!! i have unhooked everything i even took all the tape off of my old harness and all the wires were still good there were a couple questionable ones but none that could cause all off this im glad i replaced the harness but im still left with the ecu popping every time i hook up the battery
Please help i am ordering a new ecu for it tomorrow but any advise please!!!
Frerichs14 is offline
post #2 of 6 Old 07-25-2017, 08:39 AM
SkyDork's Avatar
Uh, well you're going about this all backwards. The new ECU was pointless. The fuse is for the power into the ECU, not out of it. The fuse is there to protect the ECU from getting a surge into it so it doesn't overvolt. Your battery/wiring harness is the problem as something is shorting it out and blowing the fuse in the circuit TO it. So you need to check each and every connection you did and measure voltage in and around those connections. Throwing more money and parts at the issue isn't the proper procedure and won't fix anything. It will make it worse actually, because now there's so many new things to check it's hard to figure out what the problem is.
And you bought a new OEM Kawasaki harness, correct? I sure hope so!
rcannon likes this.
#WordCrimes
SkyDork is offline
post #3 of 6 Old 07-29-2017, 01:14 PM Thread Starter
Frerichs14's Avatar
new Ecu fixed it Started right up and all my voltages are good.
post #4 of 6 Old 08-03-2017, 01:20 PM
nakedinseattle's Avatar
lol...i wonder who is gonna eat their shoe here...was skydork right? or is this new fixed ecu gonna last? tune in next week for the next episode of zx10arama!
SkyDork likes this.
Shut up and ride.
Nun sacciu, nun vidi, nun ceru e si ceru durmiv
nakedinseattle is offline
post #5 of 6 Old 08-04-2017, 08:16 AM
SkyDork's Avatar
Oh snap. I've developed a good flavor for shoes these days. I eat shoes quite often.
With that being said, and the OPs issue being resolved, my next question would be if he tried plugging the old ECU back in to see if the problem reappeared? Or is the problem corrected because the harness/wiring to the ECU was unplugged, replugged, and moved around from the effort of getting to the ECU? Who knows. Just glad he got the problem fixed.
#WordCrimes
SkyDork is offline
post #6 of 6 Old 08-04-2017, 01:07 PM Thread Starter
Frerichs14's Avatar
I did plug in my old Ecu before my new Ecu arrived and it popped the fuse. I just took my bike out to our kawasaki dealer and got some new tires and they did tests on the system and everything came out perfect. They told me The only thing I should do is look at flashing my new computer to match my fuel management system but they said it was good to go. I am taking my old Ecu out to them to see what happened to it. There was only one guy that they have seen that happen to and it was on a zx6. So they think the guy befor me put in the wrong stator. It worked for a bit and then just let loose and over charged the whole system.
It needed up taking out the rec. stator. Blew my old batt up took out ever light that was on and melted some wires in my main harness not to mention my computer.
All is fixed. Been professionally tested. And the bike is running better than ever.
