Brake Problem - Kawasaki ZX-10R.net
post #1 of 6 Old 12-26-2010, 10:04 AM Thread Starter
Brake Problem
Brake problem: I got a 06 ZX10R can't get the brake pedal to come up, still spongy any suggestions?? I've tried bleeding it the old fashion way already and dont work also tried using the mighty vac and it doesnt work either.
cwboo is offline
post #2 of 6 Old 12-26-2010, 10:32 AM
RDLYN13000's Avatar
Images: 38
RDLYN13000 is offline
post #3 of 6 Old 12-28-2010, 11:44 PM
Nutter34's Avatar
Front brake or rear brake?
"You are only young once, but you can stay immature indefinitely."
Nutter34 is offline
post #4 of 6 Old 01-07-2011, 01:58 PM
Licensed Dist of HaterAde
TMY10ER's Avatar
I would think "rear" since he said he can't get it to come up.......is the spring hooked up?
Take a risk, and you may lose. Never risk, and you will always lose.
TMY10ER is offline
post #5 of 6 Old 01-08-2011, 08:26 PM
That's good, I must take some lessons, we still have a lot to learn
uggzmini is offline
post #6 of 6 Old 01-10-2011, 06:34 AM
Nik&will's Avatar
My bike did that last season. Here's what worked for me:
1. unbolt rear caliper
2. hold it up as high as the hose will allow you to.
3. stick a paint stirring stick or anything as thick as the rotor, between the pads so they don't come out too far.
4. bleed.
the idea is, air bubbles like to rise naturally. If the caliper is below the master you are trying to fight the bubbles by pushing them down to the bleeder.
By raising the caliper higher your pushing them in their natural direction.
Good luck & welcome to the board.
Nik&will is offline
Tags
brake problem
