ZX-10/ZX-14 subframe compare - Kawasaki ZX-10R.net
post #1 of 6 Old 12-09-2014, 06:59 PM Thread Starter
I am planning to remove the short piece of subframe from the lefthand side of my ZX-14. It will save about 9 ounces of weight. My concern is that the lefthand side subframe is there primarily to reinforce the air box/frame. The air box has a slot in it to remove the air filter and the slot presumably makes the frame weaker on the left.
So, if the ZX-10 has the same frame configuration and the same section of subframe, I will assume the subframe is fairly important.
subframe bolted by S1 and S2. The air filter slot cover is the silver plate above.
Rook is offline
post #2 of 6 Old 12-10-2014, 03:15 PM Thread Starter
A friend witha ZX-10 has informed me that it does not share the same type of frame design with the ZX-14. Any opinions on whether or not to remove the left side subframe from the 14 still welcome.
Rook is offline
post #3 of 6 Old 12-10-2014, 05:22 PM
SkyDork's Avatar
The subframe refers to the part of the frame off the rear that supports the seats. It has nothing to do with the picture you posted. The ZX-14 frame is nowhere close to the same design as the zx-10 frame. It's a backbone frame that goes directly over the motor. The zx-10 uses a twin spar perimeter type frame.
If you're referring to the piece in your picture of the ZX-14, I'm betting the Kawi engineers put it there for a specific reason. Do not remove it.
#WordCrimes
SkyDork is offline
post #4 of 6 Old 12-10-2014, 08:48 PM Thread Starter
Thanks SD. Actually, the parts fiche DOES refer to the rail on the left hand side of the ZX-14 as a subframe. I know that the tail is the only place on most sportbikes where you will see such bolt-on frame bars but apparently any part that supports the main frame is called a subframe.
The tail subframe is definitely not needed on the 14 unless you carry a passenger. It's coming off for sure.
Rook is offline
post #5 of 6 Old 12-10-2014, 09:39 PM
SkyDork's Avatar
Yes, technically any support piece that reinforces the main Frame can be considered a "subframe". It's just not the term most people identify with for those pieces. It is correct though.
The Zx-10r doesn't use those pieces.
#WordCrimes
SkyDork is offline
post #6 of 6 Old 12-11-2014, 12:56 AM
it looks like a secondary engine support as its directly below the engine mounting bolt on the s1 side. could also be their to make the frame more ridged.
RBZ10R is offline
