Gen 1: 2004-2005 PC-V & autotune on a 1st GEN - Page 5 - Kawasaki ZX-10R.net
post #41 of 57 Old 08-20-2011, 03:36 PM
OneSLOW10's Avatar
Send a message via AIM to OneSLOW10
So a few questions
-Which PC 5 should one order?
-Do you really need to worry about the ignition on a first gen? On my 05 I had a PC3, DJ Quick shifter and DJ Ignition module, but never had it tuned any way so the Ignition module was pretty much useless.
-From my understanding since the PC 5 autotune's there's really no need to pay some one to "tune" your moto?
-Schematic time OP :)
The 04 I am about to pick up has a PC 3 and I'm thinking about ripping it out in favor of the PC 5
Thanks
Judd
2005 PMR. Full Ti Evo 2, BMC Race, V-Stacks, PC3, IG Module, DJ QS (not installed), 1/5th throw (not installed), -1 +2 with Gold RK Chain, Speedo Healer V4, Removed 2ndaries, Red GiPro, Pilot Powers, Dual H.I.D.s, Brocks brackets and strap, Rear 2" Muzzy Drop, Vortex Rearsets, Scotts Damper, 2 HyperPro Dampers, Puig DB, ASV Levers, Titax Levers, Pazzo Levers, Kill switch (made to look like it's mounted), CA front/rear lights and a owner who adores her...
OneSLOW10 is offline
post #42 of 57 Old 08-20-2011, 04:30 PM Thread Starter
Balogiannis's Avatar
Send a message via MSN to Balogiannis
Originally Posted by OneSLOW10 View Post
So a few questions
Thanks
Judd
You must get a PC-V for a 3d gen ZX,and 2 posi-taps along with some thin wire. These are all the things you need to make a PC-V work on your bike.
I should really make a schematic,truth is I already have it on paper I just need to scan it. :iamwithst
Now,on 1st gen's since it only has 4 injectors,you don't need an ignition module for the quickshifter to work,just the sensor.But if you want to add some spark advance then you can get one.
Autotune is something that helps the tuner,it doesn't replace him...
Balogiannis is offline
post #43 of 57 Old 08-20-2011, 04:38 PM
OneSLOW10's Avatar
SCAN it :)
Is there more tuning options with the V versus the III in regards to being able to tweak more?
Thanks
Judd
post #44 of 57 Old 08-20-2011, 06:29 PM
sextaafondo's Avatar
So a few questions
Well.. if you did not made so far any use of the IM other than plugging it why would you say itīs useless? I've been able to improve overall the whole curve by adding or subtracting advance where it was necessary so I deffinitely say it is worth, unless you are a turbo/nitrous guy who only cares for big hp increase numbers
How would you know which it the best AFR? You may get close but only that.
As Balogiannis said itīs a tool but it does not replace a good tuner with a dyno. It saves time.
Thanks
Judd
SCAN it :)
There are indeed a lot more tuning options with the PCV than with the PC3
Thanks
Judd
sextaafondo is offline
post #45 of 57 Old 08-20-2011, 08:30 PM Thread Starter
SCAN it :)
Thanks
Judd
As I mentioned before,PC-V has more tuning capabilities than 99% of the people are going to use. Comparing it to the PC-III is simply unfair. If you just want to make a map that corresponds to your mods and call it a day,then both devices are similar and will get you there with the same results.
From there on,PC-V is more configurable,per gear and per cylinder maps ( so far I haven't seen anyone making individual maps for each cylinder,and only a few spent the time to make 6 maps,one for each gear.)
2 maps via a map switch
Autotune
Ability to control eight injectors with the Secondary Fuel Module
And a few more more specific like guel enrichment per boost etc...
I even used it as a datalogger ( sort of) to help me make maps for my race ECU...
post #46 of 57 Old 08-20-2011, 09:38 PM
OneSLOW10's Avatar
I wasn't saying the IM was useless. I just meant it really did nothing for me since I never tuned everything. Since you made advancements did it help in creating a better power curve?
Kinda thinking about staying with the PC3 the more I think about it, but just thought the PC5 with Autotune was kinda cool :)
post #47 of 57 Old 08-20-2011, 10:19 PM
Yes, undoubtedly help producing more power up top and improving thottle response very clearly all over the entire rpm range. It takes a lot of time and dyno work to extract the utmost performance out of it. Switching back to a zero map shows the dramatic difference in behaviour, specially if you have mods like increased compression or head work.
There is a PCV IM now though. It's a matter of budget. You have all the hardware already so better try to tune your IM first.
post #48 of 57 Old 08-21-2011, 10:27 AM
DAXENOX's Avatar
Images: 11
Send a message via Skype™ to DAXENOX
italian official tester
DAXENOX is offline
post #49 of 57 Old 08-21-2011, 10:40 AM
inappropriate
hesaves0211's Avatar
Images: 67
impressive research man!
1ST GEN-10R 234hp/100ft.lb@6psi, GT2871RS, cometic gasket, tial bov/ex wastegate, BEGI FMU, WALBRO fuel pump,falicon clutch basket,race pak clutch,200/50 pilot,yana-shiki levers,.net wristband, WEGO III,PC3,GPR damper,cbr cals/Galfer SS brake lines,gp shift,1/5 throttle, 2NDARIES REMOVED <<click for how-to, *R.I.P D.J 10 Apr 04*
hesaves0211 is offline
post #50 of 57 Old 08-21-2011, 02:33 PM
2k3gixxer1000's Avatar
id love to see the scan of the wiring you said you had.... i think ill do this over the winter... now the question is... could we do this with a bazzaz zfi/tc?
2k3gixxer1000 is offline
You may not post replies
