Gen 1: 2004-2005 PC-V & autotune on a 1st GEN - Page 4 - Kawasaki ZX-10R.net
post #31 of 57 Old 05-26-2011, 04:41 PM Thread Starter
Balogiannis's Avatar
Send a message via MSN to Balogiannis
I'm sorry guys but I didn't took detailed pictures when I did the job,and now the PC-III is sold.
It definately helps having both devices side by side. If anyone is interested I can go to the bike and get some more detailed pics of the PC-V rewired. This should be enough for you to do the job. It's just a simple rewire after you figure out where all the wires need to go.
The plugs on the PC-V has 16 wires. Only 7 are used by the PC-V,the others are just a simple loop. I promise I will make a schematic and explain everything in detail when I get the time.
Back to the topic! Everything pluged in and working,just need to sort some minor details through the PC-V software,like calibrating the tps,configuring the map switch and autotune on-off switch...
Here is a short video showing everything connected and reasy to fire! I will also add the missing info about the grey- black/white wires on the first post!
Balogiannis is offline
post #32 of 57 Old 05-26-2011, 05:45 PM Thread Starter
Originally Posted by tasos View Post
Also can anyone buy only the wb2 without the gauge?
To change the dual maps on the pcv you need an LCD (lcd100 or lcd200)?
Sorry I forgot to answer that... Yes you can buy the wb2 only without the gauge...
To change between the 2 maps you can make a 2 map switch with a toggle button and some insulated cable,for 4-5 €... Don't buy the one from Dynojet,it's just to expensive for a simple switch!
I made my own bracket from some scrap aluminum sheet,and mounted it on the brake bracket!
http://img641.imageshack.us/img641/5896/dsc02893au.jpg
Or get the bazzaz map select switch if you don't like mine!
post #33 of 57 Old 05-27-2011, 02:51 PM Thread Starter
As far as ignition module,according to dynojet the ignition module for the PC-V is available,part 6-75.
It's a bit expensive at 359 $,but I guess it solves the ignition management problem...
post #34 of 57 Old 05-27-2011, 03:50 PM
MWCMotorsports's Avatar
so if Im goin to run a bike with nitrous and wanna be able to run two maps and watch my air/fuel. What do i all need to get the best tune out of the bike. I thought the lcd screen for the pc3 allows for 2 maps and then you can buy ignition module. What benefit is there to buy the pcV and doin this? cause then if i wanted a screen and ignition tuning id buy those seperate as well correct? Sorry new to this power commander stuff and tryin to comprehend all of this haha
Im basically wanting something to get me a good tune, with something to watch my air/fuel and everything, also something to tune my ignition. Just wondering whats the best option. I like the dynojet lcd screen cause i was gonna fiberglass it into the tank on my show/drag bike but idk
Also have a friend wanting to sell me a innovate wideband of his 02 prelude, said it retailed for over 300 and he only wanted 75 bucks for it, sounds like a good deal but would that work
MWCMotorsports is offline
post #35 of 57 Old 05-27-2011, 04:10 PM Thread Starter
Number one reason for fitting a PC-V instead of a PC-III is the autotune,and then having 2 maps with a press of a button. ( normal fuel,race fuel etc)
On a 1st GEN which has 4 injectors you can also have quickshifter function without the Ignition module,QEM,or SFM.
These 3 reasons are good enough to justify the purchase of a PC-V instead of a PC-III,especially if you like to tweek the bike your self.
If you are using nitrous then you could easily set-up a momentary switch to your nitrous button,so every time you spray the 2nd ( richer-nitrous map) comes into play, and as soon as you you stop spraying you are back to your normal map... How does that sound? You can even set up your map per gear if you like to push the limits...
If you like to monitor your AFR then you can purchase a wideband 2 & gauge,and monitor your AFR through the gauge.
Or just get the LCD screen from dynojet and datalog everything...
There are so many things that a PC-V does over the PC-III,so many that most people don't even bother to play with!
post #36 of 57 Old 06-19-2011, 09:51 PM
Did you ever make a wiring diagram cause I really don't wanna have to buy a pc3 to rewire the pc5?
post #37 of 57 Old 06-22-2011, 05:29 AM Thread Starter
No I didn't,but I think I'm able to take some detailed pictures of the 2 units side by side.
post #38 of 57 Old 06-22-2011, 11:29 AM
Ok that'd be awesome
post #39 of 57 Old 08-16-2011, 03:36 AM
Post Whore
-Op-'s Avatar
thread revive!! any updates to this??
-Op- is offline
post #40 of 57 Old 08-16-2011, 05:10 AM
cursed's Avatar
Yep there are some
Who dares, wins.
cursed is offline
You may not post replies
