Gen 1: 2004-2005 PC-V & autotune on a 1st GEN - Page 2 - Kawasaki ZX-10R.net
post #11 of 57 Old 05-20-2011, 08:30 AM
tasos's Avatar
Also can anyone buy only the wb2 without the gauge?
To change the dual maps on the pcv you need an LCD (lcd100 or lcd200)?
I have an XML on the gen1, you won't regret it !!!
tasos is offline
post #12 of 57 Old 05-20-2011, 08:56 AM Thread Starter
Balogiannis's Avatar
Send a message via MSN to Balogiannis
Originally Posted by tasos View Post
Do you need to weld 2x O2 sensors on the gen1 exhaust, or one is enough?
Why weld 2 bungs? Hamaguchi exhaust already has a bung installed so I didn't need to do anything on the exhaust...
Even if you have 2 bungs,you can't use them at the same time with 1 sensor
You can always dive into the deep of individual cylinder tuning using 4 sensors and a datalogger,and then adjust the mixture through PC-V for each cylinder separately... But that is just too time consuming if you are tuning alone,and the benefits for a almost stock bike like the most out there would be minimal...
Or if you have the cash you can buy a Motty AFR tuner and it's expansion unit,and let it work it's magic!
But the cost would be almost 1500 ...
Ι know! I got one from bayboy and it's already here waiting to be installed! Just need to get an extra harness...
Originally Posted by 08zx10rny View Post
that is very sweet. reps to you so this means i can probably do that with a Bazzaz setup as well. i have the bazzaz tc replacing the regular bazzaz fi on my 08. was going to sell it but now i interested if i could rewire it to make it work on the 05.
subscribed 100%
Bazzaz is quite different,as it plugs directly on the injectors and the coils,I installed a ZFiTC on a 3rd Gen once... ( lot's of wires )... 3d Gen ZX 10 has 8 injectors,1st Gen only 4. What are you going to do with the extra 4 injector plugs? Will it work without them connected? I don't think the injector plugs are even the same between the 2 models... Lots of things to worry about,+ the autotune of the bazzaz is not as good... A lot of people have issues with it... I thing this unit exists mainly for it's traction control,if you don't want that then go the dynojet way...
I find it very challenging,at least...
Balogiannis is offline
post #13 of 57 Old 05-20-2011, 05:32 PM
I had the tech over at Dyno Jet build me a PC5 i'll take some pics this weekend and post them. I'll be under the tank so why not
FINCH19 is offline
post #14 of 57 Old 05-20-2011, 06:04 PM
copperelite's Avatar
Send a message via Skype™ to copperelite
so my question is with autotune will i be able to switch between e85 and regular gas. will it be able to pick up the differences???
copperelite is offline
post #15 of 57 Old 05-21-2011, 02:45 AM Thread Starter
If you are asking me,I'd use the autotune to make 2 different maps for the different gasolines.
Then I'd removed it,and change between the maps via the map switch. I don't want it making adjustments all the time,bike runs better without it.
post #16 of 57 Old 05-21-2011, 03:55 AM
theatiss's Avatar
keep up the god job nick...
theatiss is offline
post #17 of 57 Old 05-22-2011, 07:28 AM
cant wait to see this i was just going to get a pc III now im going to wait and get a PC V
RenegadeZX is offline
post #18 of 57 Old 05-23-2011, 02:15 AM Thread Starter
Today I'm going to install it on the bike... I'll post some pics later!
post #19 of 57 Old 05-23-2011, 08:05 AM
sextaafondo's Avatar
I feel interested in the PCV Ignition Module. Is your guess that it can be adapted as well?
I would upgrade my whole PC system in that case.
Great work so far. Congrats
sextaafondo is offline
post #20 of 57 Old 05-23-2011, 08:32 AM
tasos's Avatar
I am sure he will sort it out
But the new IM should fit right in the pcv ?
Edit: Do they use the white connectors now?
tasos is offline
You may not post replies
