How To: Rifleman 1/5 throttle insert 06-07 ZX-10R - Kawasaki ZX-10R.net
post #1 of 63 Old 12-23-2008, 11:55 AM Thread Starter
edouble's Avatar
I know that there are a couple how-to's about this but there has been some confusion with some members including myself on how to install the 1/5 throttle insert. Here is how I did it.
EDIT by Moderator bluedevil...discuss this thread here How To: Rifleman 1/5 throttle insert 06-07 ZX-10R
Tools needed:
- Phillips screwdriver
- Dremel tool
- Dikes
The tabs inside the top throttle housing need to be ground out. I used a dremel tool.
The lock nuts on the throttle cables need to be cut off. I used a pair of dikes. *****FOR SOME PEOPLE THIS DOES NOT NEED TO BE DONE******
If you have a gap in the housing after it is bolted together more adjustment is needed on the acceleration cable (top throttle cable). The throttle grip will also be slow to return from WOT.
Unbolt the throttle housing. Threads on the acceleration cable will have to be cut to allow the adjuster to screw all the way in. I used a dremel tool be very careful not to cut into the throttle cable.
Bolt the housing together; keep in mind the above steps to bolt the housing together properly.
edouble is offline
post #2 of 63 Old 12-23-2008, 11:58 AM Thread Starter
edouble's Avatar
I wanted to post this in the how-to section but I am not able tp start new threads there
edouble is offline
post #3 of 63 Old 12-23-2008, 12:11 PM
luxurylows's Avatar
Now thats what a "how too" thread should look like... NICELY DONE edouble
IM THE GUY YOUR MOM WARNED YOU ABOUT!
luxurylows is offline
post #4 of 63 Old 12-23-2008, 08:58 PM
can we ride yet!?!?!?
coolgjc's Avatar
i trust you've tried it out...whatcha think??
coolgjc is offline
post #5 of 63 Old 12-23-2008, 09:01 PM
Accountant in training.
Deer Elk's Avatar
I am not sure, but I think a mod needs to move it to the 'how to' section...
Chris
Deer Elk is offline
post #6 of 63 Old 12-23-2008, 09:02 PM Thread Starter
edouble's Avatar
ehh....I have 8 inches of snow on the ground and subzero wind chills! Unfortunately it will have to sit a couple more months yet. I can tell you that if you watch the second video it reduces the amount of twist to get to WOT by a lot, it is going to be fun!
edouble is offline
post #7 of 63 Old 12-23-2008, 09:03 PM Thread Starter
edouble's Avatar
Chris
I PM'd a moderator and he copied this to the How-To section. I wasnt able to post there myself.
edouble is offline
post #8 of 63 Old 12-23-2008, 10:11 PM
Great write up !!! Easy to see and understand what needs to be done for this mod....
vspec1 is offline
post #9 of 63 Old 12-24-2008, 07:40 AM
great write up! Just to add for others I would try it first without cutting the lock nuts off. Mine worked perfect with them left on screwed all the way in.
tbcustomz is offline
post #10 of 63 Old 12-24-2008, 01:50 PM
coolgjc's Avatar
ya same here...lots o' ice everywhere. i just asked because i got one already and know how much i love it. becareful first few rides. it takes a little getting used to but after that, it made the bike feel like it should have came from the factory that way.
coolgjc is offline
You may not post replies
