How To: Rifleman 1/5 throttle insert 06-07 ZX-10R - Page 3 - Kawasaki ZX-10R.net
post #21 of 63 Old 03-01-2009, 06:41 PM Thread Starter
edouble's Avatar
Originally Posted by caboose View Post
I did mine today.
I did end up having to cut some of the threads off. My adjusters are nowhere near where they are shown in the write up though. Ah well.
Took me about an hour with everything off the bike already.
Did you have an 04-05? The write up is for 06-07 but same concept.
edouble is offline
post #22 of 63 Old 03-01-2009, 06:53 PM
caboose's Avatar
Send a message via MSN to caboose
Yes, an 04. That explains a lot.
2010 10R Superbike
caboose is offline
post #23 of 63 Old 03-01-2009, 07:25 PM
Я - Ребенок Люциферов
Vonstallin's Avatar
Images: 16
Ok did the 08 last night...
I didnt cut off the lock nut, but I instead cut that amount off the turning cable, left the lock nut on and cut 1/4 thread off....
perfect snap...also cut a calbe grove in the throttle clip.....
WERA Novice 325 | CCS Novice 326 | The Nightmare of Summit Point
2016 ZX10R ABS (Street) | 2011 ZX10RR(Race) | 2011 R6 (Street & Track) | 2009 WR250F
GunnRunnaz.com|GR on FaceBook | www.2666ad.com|
Vonstallin is offline
post #24 of 63 Old 03-11-2009, 09:03 AM
fantastic write up, i had to cut 1/4 thread and locknut off the accel cable only, and have decel cable adjusted 1/4 out... works perfect :)
also thread locked housing back together to be safe
06 ZX10 - Akrapovic Cans / 5th turn throttle / BMC / BikeVis Running Lights / PC3 / Pyramid Hugger / Powerbronze Screen / Rizoma Billet Res / Heat Shields Deleted / Racelab Suspension Setup / Evotech Eliminator / 16t Front / Speedohealer (-14%) / GIpro mode 1 / Ex valve disabled / Gutted Cat / 6k HID low beam / Secondarys Out / Stebel Nautilus Air Horn / PP 2CTs / Custom map / 166 rwbhp :)
BikeVis - Unique LED Running Lights
Fluke is offline
post #25 of 63 Old 04-11-2009, 01:04 PM
russell's Avatar
i didn't even have to cut off the lock nuts. took about 15 mins.
That is the Curse of Speed which has plagued me all my life. I am a slave to it. On my tombstone they will carve, "IT NEVER GOT FAST ENOUGH FOR ME."
-Hunter S. Thompson
russell is offline
post #26 of 63 Old 04-11-2009, 01:38 PM
POPO10R's Avatar
Will the insert make it easier to sustain the balance point riding up on one? Or does it make it too twichy?
Time will prey on you, and drag you thru hell....
TIE THIS AROUND YOUR NECK! :deathmeta
PRAY FOR VILLAINS
POPO10R is offline
post #27 of 63 Old 04-11-2009, 03:40 PM
drock41's Avatar
Send a message via AIM to drock41
sorry if im being ignorant but where did you pick up your 1/5th throttle insert. i am very interested in doing this mod
"Faster, faster, until the thrill of speed overcomes the fear of death."
drock41 is offline
post #28 of 63 Old 04-11-2009, 04:33 PM
Guilty by association
CP10R's Avatar
that is very helpful, nicely done
General "Mad Dog" Mattis
CP10R is offline
post #29 of 63 Old 04-11-2009, 05:04 PM
russell's Avatar
send a PM to rifleman.
-Hunter S. Thompson
russell is offline
post #30 of 63 Old 04-11-2009, 07:23 PM
leland's Avatar
This might be a stupid question, but people are having to cut bolts off and threads, to allow more cable to come out so theres enough cable to fit around the insert?
Got it to work, just had to loosen up the top bolt only.
leland is offline
You may not post replies
