How To remove KLEEN / AIS for Cal / 50st bikes - Page 5 - Kawasaki ZX-10R.net
post #41 of 148 Old 10-07-2004, 06:51 PM
Post Whore
Frankyoz's Avatar
Ok, call me an idiot but why did everyone do this again, was it just for weight reduction? I havent read anywhere if it really helped hp gains or performance? Once again if I missed it let me know.
Frankyoz is offline
post #42 of 148 Old 10-07-2004, 07:01 PM
Send a message via AIM to gladding24
weight, and it reduces the amount of popping/backfiring you hear with an aftermarket exhaust. No HP benefits though.
Stop Whining!!!
It ain't easy being Green ~ Kermit The Frog
Arguing on the internet is like running in the Special Olympics.....Even if you win...you are still retarded
CaliSuperbikes- "these are high strung machines, and we're giving them a constant dose of Red Bull"
gladding24 is offline
post #43 of 148 Old 10-07-2004, 07:44 PM
Post Whore
Frankyoz's Avatar
It sounded to me like the backfiring increased when the KLEEN was messed with? I mean isnt the clean there to catch unburned fuel and make the engine burn more efficiently to meet cali standards? I would imagine by removing this it would increase the chances of backfire. I mean isnt a backfire fuel catching inside your canister causing a audible pop as it burns or creates a small explosion?
Frankyoz is offline
post #44 of 148 Old 10-07-2004, 08:59 PM
Sort of Frank, The only thing the AIS(Air Injection System) does is pump fresh air into the exhaust just after the exhaust valves. This allows any unburned fuel leftover from the combustion process to mix with the fresh air and burn in the pipe. the stock pipe has enough baffling so you don't really hear the backfiring, but with an aftermarket pipe you do. Installing block off plates stops the flow of fresh air into the exhaust and reduces the amount of 'afterburning' that occurs in the exhaust pipe.
Stop Whining!!!
post #45 of 148 Old 10-07-2004, 09:38 PM
Omega's Avatar
Originally Posted by Big Daddy
As you've either found out or are going to the vacuum caps are only required if you leave the OEM plates intact but since your using the plates from DK theres no need.
You do need some vacuum caps even if you are installing the block off plates.
On my CA model there was a small 4mm (0.160") nipples coming out of the Cyl#1 throttle body and the Cyl#2 throttle body (2 total) that I had to plug. You can use 1/8" vacuum caps here. If memory serves me correctly these were attached to the charcoal canister.
Also there is the large nipple 15mm (0.590") coming out of the bottom of the airbox/throttle plate. You can use a 5/8" cap here. This nipple supplies air to the air solenoid that is removed with the installation of the block off plates.
Hope that helps
Omega is offline
post #46 of 148 Old 10-07-2004, 11:09 PM
:iamwithst
ZX-10Rrider is offline
post #47 of 148 Old 10-08-2004, 04:34 AM Thread Starter
Big Daddy's Avatar
Images: 38
Hope that helps
Omega all of this is mentioned in the very beginning of the thread.
My reply to SMbowen was mearly to let him know that the DK plates do not require any vacuum caps BUT if someone is using the exhisting OEM plates then yes they will require two 5/8" caps.
Big Daddy is offline
post #48 of 148 Old 10-08-2004, 12:01 PM
livnpaintball's Avatar
I Bought Some Block Off Plates From Ivans Performance And They Are Top Notch, He Stated That The Fi Light Will Come On.. A Resistor Is Needed To Prevent This. It Should Be As Simple As Taking A Meter And Read Across The Valve Poles And Going To Radio Shack For The Resistor.. Has Anyone Done This Yet? If Not I Will This Weekend.
z50(first bike) way gone
cb125,cr250,xl250,xr350,zx600,fz600x2,
97' cbr900 totaled
98' TLR totaled
00' ZX9 sold
04' ZX10 met lime green, track bike now
08 CBR1000RR red/silver!
livnpaintball is offline
post #49 of 148 Old 10-08-2004, 12:15 PM
dnwhoop02's Avatar
I installed the Dan Kyle block off plates, and the FI light didn't come on.
David Nolden
CMRA #711
dnwhoop02 is offline
post #50 of 148 Old 10-08-2004, 10:43 PM
It Will Give It Time
97' cbr900 totaled
98' TLR totaled
00' ZX9 sold
You may not post replies
