How To remove KLEEN / AIS for Cal / 50st bikes - Page 4 - Kawasaki ZX-10R.net
post #31 of 148 Old 06-30-2004, 01:05 AM
hmmm, counterclockwise is 6, 5, 4, 3....?
tilt toward you or away?
I have Dan's block off plates and once I get the vacuum caps I'll need to be back in there.
Jonathan
jmg893 is offline
post #32 of 148 Old 06-30-2004, 01:10 AM Thread Starter
Big Daddy's Avatar
Images: 38
as you probably noticed theres an indent in each frame rail thats there so the box fits very snug, well once you've turned it a 1/2 turn counter clockwise tilt it so the bottom of the box sticks up somewhat and as you lift it continue turning until it comes loose.........well atleast thats my version of how i did it a couple of months ago.
Big Daddy is offline
post #33 of 148 Old 06-30-2004, 10:38 AM
ok, thanks
Jonathan
jmg893 is offline
post #34 of 148 Old 07-05-2004, 10:58 AM
My understanding is that the plates prevent back firing under de-excelleration. How back does the back firing have to be to warrant all this trouble? I'm told that my bike back fires but I've never noticed it.
Vroom, Vroom
stanmann is offline
post #35 of 148 Old 07-06-2004, 01:41 AM
Louks03's Avatar
Send a message via AIM to Louks03 Send a message via MSN to Louks03 Send a message via Yahoo to Louks03
The backfiring just irritates me ... I'ts probley not goona screw anything up.
www.doodie.com
Louks03 is offline
post #36 of 148 Old 09-17-2004, 12:52 AM
Originally Posted by Big Daddy
as of just a couple of days ago my FI light has come on and has remained on. I've made to changes since my KLEEN/AIS removal.
Hey BD,
Did you find out what caused the FI light to come on? I am in the process of removing the KLEEN solenoid and was wondering if it is worth it? I also plan on installing the block-off plates. If it causes the FI light to come on, I don't think I want to do it. Anyone with knowledge of this procedure is welcomed to answer.
ZX-10Rrider is offline
post #37 of 148 Old 09-17-2004, 12:50 PM Thread Starter
Big Daddy's Avatar
Images: 38
The FI light eventually went off on its own, so not knowing why it was activated in the first place leaves me wondering WTF!! perhaps it was due to moisture/wetness after i washed it and the once the water evaporated it went off (guess only)
suffice to say the FI light never came on prior to the bubble bath
8-)
post #38 of 148 Old 09-17-2004, 02:37 PM
Thanx BD
post #39 of 148 Old 10-07-2004, 04:40 PM
I realize now that unfortunately I am one of the "retards" and not in the "vast majority". I was feeling comfortable about doing this when I got the plates from Kyle's and read through a couple of posts. But does anybody have pictures or more information on the charcoal canister? Do I need any vacuum caps if I am using plates?
Any help is greatly appreciated.
THANKS!!!!
"sm"
Shawn M Bowen
SMBowen is offline
post #40 of 148 Old 10-07-2004, 06:43 PM Thread Starter
Big Daddy's Avatar
Images: 38
THANKS!!!!
"sm"
Shawn M Bowen
As you've either found out or are going to the vacuum caps are only required if you leave the OEM plates intact but since your using the plates from DK theres no need.
You may not post replies
