How To remove KLEEN / AIS for Cal / 50st bikes - Page 2 - Kawasaki ZX-10R.net
post #11 of 148 Old 06-19-2004, 09:07 PM
OG Post Whore
stunnerific_harry's Avatar
Send a message via AIM to stunnerific_harry
do you live ont he west coast? if so could you do it for me ill buy you something for your bike j/k
stunnerific_harry is offline
post #12 of 148 Old 06-20-2004, 09:18 AM
CanyonCarver's Avatar
Gladly. But I think I'll take a new bike to go with all the somethings I have, instead. I won't be able to work on anything until the collar bone heals, tho.
CanyonCarver is offline
post #13 of 148 Old 06-21-2004, 08:29 AM
dnwhoop02's Avatar
Originally Posted by Big Daddy
It's a pretty straight forward job using some basic tools once the seat, black side panels (2), gas tank, and both side body panels are removed for easy access to the solenoid
yeah, easy access my ass!
Canyon- when you installed the block-off plates, did you use any silicone grease around the edge to seal them? Or do you think that's important? I got one plate installed last night, and didn't think about using the grease until after it was all tightened down. I really don't want to have to pull it back off if I don't have to since the forward bolt is a pain in the ass to get to.
Also, I wonder if it might be a good idea to wire up a resistor in place of that air solenoid thingy so the ECU won't notice that it's gone. Just a thought....
David Nolden
CMRA #711
dnwhoop02 is offline
post #14 of 148 Old 06-21-2004, 09:10 AM Thread Starter
Big Daddy's Avatar
Images: 38
:D
Big Daddy is offline
post #15 of 148 Old 06-21-2004, 09:47 AM
Nope, didn't use any grease or sealant of any kind. Thought about it, but the gaskets/seals that were in place looked nice and clean & fresh, so I figured I'd try without and re-do if they didn't seal properly. Luckily, they sealed fine without any help.
As for the resistor idea, I just removed the solenoid. It didn't cause any issues with the ECU as far as I can tell. No codes or FI lights flashing. It would appear that it doesn't feed back problems to the ECU.
BTW, yeah the bolts are a pain to get at. I didn't remove the side panels, but am a professional contortionist with an allen wrench.
post #16 of 148 Old 06-21-2004, 10:02 AM Thread Starter
Big Daddy's Avatar
Images: 38
as of just a couple of days ago my FI light has come on and has remained on. I've made to changes since my KLEEN/AIS removal.
post #17 of 148 Old 06-21-2004, 11:09 AM
dnwhoop02's Avatar
Canyon- There aren't any seals/gaskets in there.... are you talking about the reed valves? I wasn't sure if the bolts that came with the plates were long enough to keep those in, so I removed them.
David Nolden
CMRA #711
post #18 of 148 Old 06-21-2004, 01:09 PM
Yes I am. The reed valves stay in place. If you remove them, you've lost your seals. I'd suggest you put them back, and things should be fine. The bolts do seem a bit short, but I had no problems with them. If you are using the Kyle plates that I have, the bolts should be the correct length.
post #19 of 148 Old 06-21-2004, 02:23 PM
dnwhoop02's Avatar
aww man.... those reed valves are way too heavy! I'm looking for MAXIMUM weight reduction here... :D
David Nolden
CMRA #711
post #20 of 148 Old 06-21-2004, 03:50 PM
Well, I suppose you could take the ol' die-grinder to the inner portion of them, to reduce the weight of the valve. Just be sure to leave the sealing portion alone.
Then again, I've seen people use JB Weld to seal the passages before. I imagine this would save weight, but at what price, I don't know. :roll:
You may not post replies
