How to: install filter on 06-07 - Kawasaki ZX-10R.net
post #1 of 1 Old 02-14-2009, 06:39 PM Thread Starter
DSM_David's Avatar
Send a message via AIM to DSM_David
1.to start you have to take off the fairing pieces right under the seat. they just pop off when you remove the 1 allen key bolt.
2.next would be to remove the seat by removing the 2 allen bolts under the seat.
3.next would be to remove the 2 allen bolts on top of the steering stablizer
4. next would be to loosen the 10mm bolt behind the gas tank. dont take it out because you have a overflow hose, gas line, and a plug to remove.
5. next flip the gas tank up carefully and remove the overflow hose, gasline, and plug.
6.remove the 10mm bolt and remove the gas tank
7.remove the 8 Philip head screws on top of the filter box.
8.replace filter. reverse steps to put everything back together...
Discus this thread here:
http://zx-10r.net/forum/showthread.php?t=70227
Faster and faster, until the thrill of speed overcomes the fear of death
two brothers slipon's, dog bones, puig double bubble windscreen, -1 front sprocket, ivans tre, frame sliders, bar ends, rear spools, k&n filter
DSM_David is offline
You may not post replies
