Hellsrazor's *HOW TO* Figure out Gen 1 "FI" Light / Code Simplified - Kawasaki ZX-10R.net
 2Likes
  • 1 Post By hellsrazor
  • 1 Post By YSR50
post #1 of 2 Old 10-15-2011, 02:50 AM Thread Starter
Servo's Eliminatus ;)
hellsrazor's Avatar
Images: 23
I decided to do a write up with pics to share with my fellow ZX10R.NETTERS.
I made it very simple to follow.
Here Bro's
Maybe make it a sticky, what do you guys think.
1. Remove rear seat / cowl.
2. Remove the two screws on the panel
directly behind the front seat & remove panel.
3. Remove Front seat.
4. Locate the bike "DEALER MODE" wire and female connector
Pictured 1, 2, 3. Below ( Pointing at it with highlighter)
5. Take a piece of small wire (approx 14") and strip both ends.
6. Insert one end into "DEALER MODE" connector.
7. Ground other end of wire to either seat bolt hole
or negative terminal on battery.
8. Turn key ON and watch the FI light flash.
There will be a series of slow then fast flashes.
Count the Slow flashes & Fast flashes
i.e. 1 slow flash & 5 Fast flashes is a Code 15
*** IMPORTANT***
If you have more than 1 problem with your bike,
it will display all error codes from the lowest # to the highest #.
********NOTE********
Have a piece of paper and pen to write down the
slow / fast flashes.
SERVICE CODES are listed below.
ofanaim likes this.
hellsrazor is offline
post #2 of 2 Old 01-06-2013, 05:46 PM
Administrator
YSR50's Avatar
Images: 32
Discuss this topic here: http://zx-10r.net/forum/showthread.php?t=108218
Simpkins likes this.
"Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind."
--Dr. Seuss
YSR50 is offline
You may not post replies
