fitting gen 2 dash instruments to gen 1 ZX10R - Kawasaki ZX-10R.net
post #1 of 21 Old 02-27-2009, 06:24 PM Thread Starter
Hi Folks,
I have an '05 model ZX-10R but hate the weirdo LCD tachometer. I'd like to replace that with the instrument cluster from the 2nd gen '06 model bike.
Checking the service manuals shows that the wiring is reasonably similar - the only difference I can see is that the g2 bike has a single wire for oil pressure + FI warning - but I hear rumors that the later model bike has a very different speedo sensor which would impact the speedo reading...
Has anyone done this swapout successfully ? If so could you please let me know exactly what's required ? Detailed instructions with photos and wiring diagrams would be greatly appreciated.
Thanks !!!
Rob
robby-hk is offline
post #2 of 21 Old 02-28-2009, 12:25 PM
Dragone's Avatar
Images: 11
That change out was explained in 2006 I think it was. You will find that it is not an easy swap. Do a search for it. Good luck
edit: My only contribution to that topic.....was a frickin scan of the 2nd gen pin layout. Now I need to relook that one up. lol
W.F.O.ing with style will bring life back into focus
Dragone is offline
post #3 of 21 Old 03-03-2009, 06:02 AM
Yui
Yui's Avatar
Images: 12
I installed a Z1000 Dashboard on my '05 race bike, the basics are full functionally except the fuel gauge. (I don't have it)
Sorry but I don't need turn lights, chronometer or headlight, and I don't connected this, but I think that will work well.
ZX10R 2005, Kevlar brake hoses, Lowering bones, Intake kit camshaft, Leovince Evo2 full Exhaust, Brembo master brake 19x18, Fiberglass fairing, Brembo M4 Calipers, PVM Wheels, Axis front Rotors.
Yui is offline
post #4 of 21 Old 03-03-2009, 10:20 AM
BornSinner's Avatar
Images: 19
Send a message via AIM to BornSinner
I think BlueDevil has done that swap....and very clean look also....
BornSinner is offline
post #5 of 21 Old 03-03-2009, 04:39 PM
Dragone's Avatar
Images: 11
Yes, BlueDevil was the one that instigated the try out and to see if it would work.
Dragone is offline
post #6 of 21 Old 03-04-2009, 09:44 AM
Yui
Yui's Avatar
Images: 12
This is my dash installed
Yui is offline
post #7 of 21 Old 05-15-2009, 08:20 PM Thread Starter
Done !!!!
Thanks to all for the help.
the overall process was :
1. source new gauge - I used Ebay
2. open gauge, de-solder new cluster's female connector block
3. source Acumen DG8 wiring loom - cut off most of it but retain female connector for 04/05 model wiring harness + tail cables.
4. solder tail cables into the slots vacated by the 06/07 connector. Note wiring is similar but not entirely the same as the older model. Check manuals for details. Or PM me, I have the pinouts
5. cross-connect the cluster's 12v power input to the to the gen1 bike's speed sensor power wire - the gen2 cluster doesn't supply this
6. source & setup Speedo Healer v4 to compensate for the 7.4x difference in speedo sensor pulses between Gen1 & Gen 2 bikes.
7. Enjoy
robby-hk is offline
post #8 of 21 Old 05-16-2009, 04:02 AM
mr747's Avatar
you got pics please show me
FULLY LOADED :)
mr747 is offline
post #9 of 21 Old 05-16-2009, 09:22 AM Thread Starter
sure but I can't seem to get them to upload to the forum ? it keeps giving me an error message, or timing out or something. Is there a file size limit ?
either way I'm happy to share all the info I have, PM me for more details.
Cheers
Rob
robby-hk is offline
post #10 of 21 Old 05-16-2009, 09:42 AM
mr747's Avatar
do you have a how to??? on this swap
FULLY LOADED :)
mr747 is offline
You may not post replies
