eBay Rear Sets - Review with Pictures - Kawasaki ZX-10R.net
post #1 of 2 Old 08-22-2010, 12:00 PM Thread Starter
Adr3naline fix's Avatar
Send a message via AIM to Adr3naline fix
A few weeks back I lowsided at the track. I broke my brake pedal and decided that it was was not worth replacing at $95.96 from the stealership. So I found these little gems on eBay for about $214 including shipping.
http://cgi.ebay.com/ebaymotors/04-05..._9 584wt_1028
They are a direct copy of the Sato rear sets, even with the same 7075 aluminum. If I were to have $500 to spend on the Sato's, I definitely would have bought them - please keep in mind that this is for the budget rider/racer.
I received them within 10 business days - not bad for China.
Now, in my mind, rear sets are rear sets if; they can be adjusted, they can hold a gorilla, have replacement parts available, and have no functionality issues.
Few notes:
  • You use most of the stock mounting hardware, including the shift rod if you want to keep standard shipping (comes with a GP shifting rod - which is extended).
  • The brake pedal does not need a spring due to the smooth ball bearings
  • The pegs will try and come loose on you if you don't put lock-tite on the threads, I would also recommend lock-titing the shift and brake knobs themselves
  • There is a support for the stock brake light actuator
  • Easy to install with 3 different allens and a crescent wrench
  • The shift action feels much more solid and satisfying than the stock linkage
  • Yes I know my chain needs to be replaced (and was) after the pictures
  • Milwaukee garbage system sucks
Overall - very happy for ~$215. I don't normally post reviews, but the manufacture of these Sato knock-offs was very helpful, and quick to respond. Would recommend these to anyone.
ID:	134556   Click image for larger version
ID:	134557   Click image for larger version
ID:	134558   Click image for larger version
2004 ZX10R is Sold
Adr3naline fix is offline
post #2 of 2 Old 08-22-2010, 12:17 PM
dirt ninja's Avatar
Images: 9
Thread discussion: eBay Rear Sets - Review with Pictures
Marchesini Magnesiums,Nassert beet,kawi cam,.45 headgasket,DJ PC/Ig.M/QS,velocity stacks,bmc race,gipro,sato rearsets,helibars,throttlemeisters,pazzo shorties,speedohealer,520 renthal sprockets,penske 8393 double clicker,traxxion dynamic springs,scotts stabilizer,lsl frame sliders,cox radiator guard,powerbronze hugger,puig DB,solo seat cover,Valentine1,dual low beam projectors,55w.hids, brembo superbike rotors,Goodridge superbike lines,nissin calipers and rizoma mirrors,mda123 battery.
dirt ninja is offline
You may not post replies
