Need 2016 OEM Front Calipers - Kawasaki ZX-10R.net
post #1 of 15 Old 02-17-2017, 03:09 PM Thread Starter
d-wire's Avatar
Anyone have a set of the Oem Brembo Front Calipers for sale? 2016 zx10R
Mine are causing massive brake drag
d-wire is offline
post #2 of 15 Old 02-17-2017, 03:33 PM
mpp12's Avatar
maybe ducati or aprillia ones fit since those gen5 use euro bolt distance.
mpp12 is offline
post #3 of 15 Old 02-17-2017, 07:31 PM Thread Starter
d-wire's Avatar
yeah, unfortunately the race orgs require the oem caliper for some classes I run
d-wire is offline
post #4 of 15 Old 02-17-2017, 08:07 PM
dricked's Avatar
They're the same caliper though if you get the right ones.
dricked is offline
post #5 of 15 Old 02-17-2017, 09:44 PM
mpp12's Avatar
Panigale are same ones m50
Enviado desde mi iPhone utilizando Tapatalk
mpp12 is offline
post #6 of 15 Old 02-17-2017, 10:39 PM
Helitech's Avatar
What would I need to run these brakes on a gen 4?
Helitech is offline
post #7 of 15 Old 02-18-2017, 04:20 PM
Gen5 front forks and wheel.
ukzx10r is offline
post #8 of 15 Old 02-18-2017, 04:22 PM
Out of interest why are they dragging?
I had a dragging on my bike that wasnt there when i brought it.
ukzx10r is offline
post #9 of 15 Old 02-19-2017, 11:21 AM
Niner1000RR's Avatar
That's a good question! Seems like nothing solves it.
He's used 2 different masters, different pads, different rotors (brand new), removed the retaining clip, etc... And they drag like crazy! Even replaced the seals and cleaned the pistons.
Mine on the other hand have been AWESOME! No drag at all!
Niner1000RR is offline
post #10 of 15 Old 02-19-2017, 11:34 AM
I heard some fuilds can cause the seals to swell.
Maybe try running standard dot4 fluid and nothing fancy with new seals in there.
One other thing is overfilling the pot causing pressure or forcing air pressure into the pot when your putting fluid in.
If its presurised it can cause dragging
ukzx10r is offline
