Need 2016 OEM Front Calipers - Page 2 - Kawasaki ZX-10R.net
post #11 of 15 Old 02-19-2017, 11:14 AM
Niner1000RR's Avatar
We both run the Castol SRF fluid, I doubt that's the issue...
Niner1000RR is offline
post #12 of 15 Old 02-20-2017, 11:55 AM Thread Starter
d-wire's Avatar
Yeah, like Nick said, its happened with new oem rotors and new vesrah pads.. same with sbs pads and brembo rotors...
two different master cylinders... plenty of air gap in the resevoir...
When the calipers are off the lines completely, the pistons still seem jammed up in the bore, like the tolerance is too tight
d-wire is offline
post #13 of 15 Old 02-20-2017, 01:28 PM
Carlos76's Avatar
If seals have made contact with break cleaner, then get new seals.
Clean seals only with warm water and soap.
Polish pistons outwards direction to set microscopic burrs in favorable direction.
We use stuff called "ATE Bremszylinder-Paste" lightly when installing pistons.
Gen4 race: high spec.
Suzuki GSX1300R Hayabusa 2013: stock.
Kawasaki KX450F 2016: love it.
Carlos76 is offline
post #14 of 15 Old 02-20-2017, 04:15 PM
Mine was after a track day where i was trying a set of sbs pads and they cooked themselves purple. They got so hot i couldnt touch the brakes at all and i struggled to change the pads back to stock because of the heat. Once changed back the brakes were brilliant straight away but i always had dragging after this.
Extreme heat can distort metal easily.
If yours have got real hot then your tollerances could be out on the pistons.
The only real way to tell is to remove pistons and use a micrometer to see if they are out of shape or size.
If they are annodised alloy like the gen4 you are screwed as you cannot polish or turn down annodised alloy.
There is a company in the uk that make stainless pistons. If you get really stuck i can make a set at work. I made castlated ones for my old calipers.
ukzx10r is offline
post #15 of 15 Old 02-22-2017, 08:10 AM
It's pretty safe to say he knows full well how it's done ;)
