valve cover gasket leaking - Kawasaki ZX-10R.net
post #1 of 13 Old 08-11-2008, 08:56 AM Thread Starter
bradshow01's Avatar
I've searched all over zx-12r.org and can't find anything about this issue. First off, what would cause the valve cover gasket to leak? Looks as if I will have to drop the motor to change it out.
bradshow01 is offline
post #2 of 13 Old 08-11-2008, 09:11 AM
SDave2002's Avatar
valve cover
I had a leaker last race of season.. Changed out first thing this year... No need to drop motor... Take off the top engine mounts that go to frame and it will be an easy change out....
FC Suzuki
FC Yamaha
CCS #38
NESBA #38
SDave2002 is offline
post #3 of 13 Old 08-11-2008, 10:44 AM
Shorty's Performance
madnessracing's Avatar
Bike is a lil too old or it has too many miles! Which is normal.
madnessracing is offline
post #4 of 13 Old 08-11-2008, 03:42 PM
11ute's Avatar
Images: 12
not to hard to change, just a bit tight dont need to drop motor
11ute is offline
post #5 of 13 Old 08-13-2008, 08:13 AM Thread Starter
bradshow01's Avatar
well its an 03 with roughly 10k, (guy dropped a tooth in the front with 100miles on the clock and never got a speedo healer) actual miles show 16k. which to me doesn't seem that being too old would be an issue and miles shouldn't really either. i'll give it another look see and see if i can get'r done
post #6 of 13 Old 10-05-2008, 04:02 AM
The 14's have the same issue. The fix is to put a washer or 2 under the bolts for the cover. The stock bolts are too long and don't cinch the cover down tight enough. not sure if its the same on the 12's tho. First thing I would do is just check to be sure all the bolts are tight. Kawi's tend to come with things loose sometimes
Red Runner is offline
post #7 of 13 Old 10-07-2008, 03:52 AM
10R Joe's Avatar
Images: 9
Mine only leaks when i put to much oil in it...
If its got tits or tires it'll give u problems
10R Joe is offline
post #8 of 13 Old 10-20-2008, 03:26 PM
Images: 14
i have a 08 zx14 with the same issue im gonna try with red runner suguested. i have about 700 miles though, im not to happy.
06 ZX10R, Akrapovic Carbon B/O's, Ivan's TRE, PCIII with Ivans map,Puig DB Black screen, Pazzo racing levers,Vortex Rearsets,Powdercoated black rear pegs,16T,Renthal 41t rear sproket,Renthal SR4 chain,speedohealerIII,GPR V1 Stabilizer,Pilot Power 2CT'S.
99zman is offline
post #9 of 13 Old 07-26-2009, 11:28 PM
Sharpright's Avatar
My 04 zx-10r did the same thing on the left side. At my last valve lash adjustment, I Cleaned the cover gasket, and reinstalled with permatex super black on both sides, and I haven't lost a drop since.
Sharpright is offline
post #10 of 13 Old 07-31-2009, 09:50 AM
n3n
try cleaning it should be able to re-use
n3n is offline
