Gen 4: 2011-2015 Fuel Tank - Kawasaki ZX-10R.net
 2Likes
  • 1 Post By realpsi
  • 1 Post By SkyDork
post #1 of 9 Old 01-26-2018, 03:53 AM Thread Starter
Question Fuel Tank
Hi Guys
Recently picked up that my bike started leaking fuel, sent her in for inspection/repairs and now the tank is completed dented in and cracked at the bottom, this bike has not been in an accident, what other causes could lead to this happening?
Thanks in advance for any replies.
Qsilver247 is offline
post #2 of 9 Old 01-26-2018, 05:38 AM
Victors's Avatar
Originally Posted by Qsilver247 View Post
Hi Guys
They don't just miraculously damage themselves for no reason. Something happened to it.
Pics?
2013 10R
2007 650R
2016 10R
Victors is offline
post #3 of 9 Old 01-26-2018, 07:12 AM
Did it vent correctly? Was the gas tank lid ever hard to open? Most tanks have very little implosion resistance.
SkyDork likes this.
2011 ZX10R
2012 FZ6R
2012 TU250X
2013 ZX6R
2017 GSX-R1000R
realpsi is offline
post #4 of 9 Old 01-26-2018, 11:25 AM
belkins's Avatar
got a picture? you say sent in for repairs.. I would be questioning the guys working on it. Is there a screw close to the hole/crack/dent? Depending on how bad it is I have used jb weld gas tank repair on motorcycle gas tanks before with great results.
2013 Kawasaki Ninja ZX-10R
~Woolich ECU Flash/Log Box/AutoTune~Driven Block Off Plates~Woodcraft Frame sliders~Cox Radiator Guard~OEM Seat Cowl~Tinted Hotbodies Venom Windscreen~Lightech Chain Adjusters/Axle Sliders/Spools~Sato Rearsets/Race Hooks/Bar Ends/Reservoir Covers~Pazzo Shorty Levers~Engine Ice~Motodynamics Rear Turn Signals~Ohlins TTX MKII Rear Shock~R&G Case Savers~M4 Street Slayer Exhaust~Ohlins Race SCU~-1 +2 520 Driven Sprockets~520 DID Gold Chain~
belkins is offline
post #5 of 9 Old 01-26-2018, 12:56 PM
SkyDork's Avatar
Welcome!
Two things that come to the top of my mind on this. First, if the vent lines were crimped/crushed under the tank improperly, it can implode the tank slightly from the fuel pump sucking the fuel out of it (as realpsi stated above). Next would be the it got removed and dropped onto something.
Without knowing exactly where it's dented though, t's hard to say.
Victors likes this.
#WordCrimes
SkyDork is offline
post #6 of 9 Old 01-29-2018, 02:01 PM Thread Starter
Here is the pic from my tank, fuel cap was never hard to open, didn't have any vacuum sounds when opening, the point is to avoid it happening again, and this truly has me stunned!
post #7 of 9 Old 01-31-2018, 12:33 PM
Looks like it imploded. Why? Good question....
The Prophet is offline
post #8 of 9 Old 01-31-2018, 02:10 PM
Judge Dredd Mod
mr_honez's Avatar
Looks like a venting issue implosion to me. I would look into that so it doesn't happen again when you get the tank back.
Oh, and !!!
BURNOUT.....
mr_honez is online now
post #9 of 9 Old 01-31-2018, 02:25 PM
Either your fuel pump did it or maybe the shop vacuum tested the tank? I don't know, but as mentioned check the venting. It takes very little to implode a tank.
2011 ZX10R
2012 FZ6R
2012 TU250X
2013 ZX6R
2017 GSX-R1000R
realpsi is offline
