Gen 1: 2004-2005 ZX10 ignition issues- won't start! - Page 2 - Kawasaki ZX-10R.net
 5Likes
post #11 of 35 Old 04-13-2018, 07:40 AM
SkyDork's Avatar
Originally Posted by Jeradcarty View Post
Hello again and I've flicked kill switch back n forth a dozen times at least , just hoping..but thanks for that.. mine won't turn over with kill switch on (not in run) but I did notice while giggling wires trying to get the sound of computer or electronics (like it did Everytime when it started) I believe all would make the sound I'm taking about.. anyways the f1 light flashes when I'm cranking it over !! Is this normal?? I can't remember if it did that before (although it always started relatively easy and quick so I never payed attention.. bike is almost stock has aftermarket pipe and I made the servo dummy plug so f1 light wouldn't be on.. (not from exhaust at least) but it's not on when keys turned on , only when cranking it over... Any help is appreciated!!!! Thanks
Jerad
Ugh! Shit! It's not an F1 light! It's an....
FI light - Fault Indication!!!
All Gens: So, your "FI" light is on.....
The light is flashing during the start sequence because your tip-over sensor (vehicle down sensor) is activated. You need to check that. The FI light should stay on steady when there's an error detected. It should not flash while trying to start - unless the tip-over sensor is activated.
#WordCrimes
SkyDork is offline
post #12 of 35 Old 04-13-2018, 01:36 PM
thundercoupe9's Avatar
F1 (Formula 1) is way cooler than FI
SkyDork likes this.
thundercoupe9 is offline
post #13 of 35 Old 04-13-2018, 01:49 PM
SkyDork's Avatar
I can't wait for the day that Formula 1 changes the name of that series to Phormula 1 (PH1)! Then I can post up about it not being an PH1 light!
thundercoupe9 likes this.
#WordCrimes
SkyDork is offline
post #14 of 35 Old 04-13-2018, 01:55 PM
I can't wait till Formula 1 changes its name to Formula I, so when i google FI it won't take me to kawasaki forums to posts of people with bike problems
michael4012 likes this.
post #15 of 35 Old 04-13-2018, 02:12 PM
SkyDork's Avatar
I hate when that happens too!
#WordCrimes
SkyDork is offline
post #16 of 35 Old 04-13-2018, 02:15 PM
Ok well excuse me for getting that wrong... FI light then , and where is this tip over sensor that you speak of?? and what's it look like ? My bike hasn't been laid over since i've owned it so kinda weird that it went out but I'll be happy as all get out if that's what it is... I will let you know as soon as i get off work and get home..
Thanks
Jerad
Jeradcarty is offline
post #17 of 35 Old 04-13-2018, 02:42 PM
SkyDork's Avatar
Thanks
Jerad
The tip-over sensor is under the fuel tank just in front of the battery. It is a black plastic piece mounted vertically by 2 bolts on either side that hold it in. It will be marked "UP" with an arrow. It has a 3-wire connector hooked to it.
Just because the bike hasn't been down, doesn't mean the sensor isn't bad. A big jolt to it like hitting it or dropping it can damage it. Or the wiring going to it is bad. Especially if it gets fuel on it since it is located right there. If we're still talking about a Gen 1 that is.
#WordCrimes
SkyDork is offline
post #18 of 35 Old 04-13-2018, 02:55 PM
Capncalyx's Avatar
Thanks
Jerad
Maybe at first sight but after being on this forum for years, ive learned its actually a super duper common thing to have happen and many times one of the first things a person will look at when doing diagnostics.
A good tuner...can make a dyno say anything it wants.
We will all die but only a select few of us will ever truly live.
Capncalyx is offline
post #19 of 35 Old 04-13-2018, 05:06 PM
Ok well that's not it or at least doesn't appear to be it.. how do I test the tilt sensor? Or jump it out to get it out of the equation?? Anyway I doubt it's got anything to do with it since it acts the same way (turns over but no sounds or ecu or anything) with sensor unplugged.. Fi light did stay on when unplugged tho and went back out when I plugged sensor back in so it appears to be working correctly... Any help is greatly appreciated!!!! And I can post a pic or video if that would help?? Idk what you'd wanna see but if ya tell me I'd be happy to help you help me....lol. Thanks to all who read this...
post #20 of 35 Old 04-13-2018, 05:07 PM
Sorry forgot attachment...lol
