Gen 4: 2011-2015 Woolich Racing Ecu Kit - Kawasaki ZX-10R.net
post #1 of 49 Old 11-22-2016, 12:03 AM Thread Starter
Does the kit allow for clutchless downshifting? If so how do you do it? And if not how can I do it where it wouldn't interfere with the woolich race kit already installed.
Jlefevre1122 is offline
post #2 of 49 Old 11-22-2016, 04:20 PM
Yes the KRT has the clutchless down shift so will you lose it in the flash?? Also if you send a blank ecu to be fladhed what's the difference ? ????
Sent from my SPH-L900 using Tapatalk
tommyboymacho is offline
post #3 of 49 Old 11-22-2016, 05:50 PM
SkyDork's Avatar
You have to enable the auto blip capability in the flash settings in the Woolich software.
#WordCrimes
SkyDork is offline
post #4 of 49 Old 11-22-2016, 05:51 PM Thread Starter
I appreciate the help
post #5 of 49 Old 11-22-2016, 06:28 PM
Can you explain auto blip what does it do exactly
post #6 of 49 Old 11-22-2016, 06:37 PM
dricked's Avatar
This thread is titled "gen 4" for which there's no auto blip avaialable through software alone
dricked is offline
post #7 of 49 Old 11-22-2016, 07:00 PM
SkyDork's Avatar
Oh shit. You're right. Missed that little tidbit.
#WordCrimes
SkyDork is offline
post #8 of 49 Old 11-22-2016, 07:04 PM
SkyDork's Avatar
The auto blip is the same thing as you blipping the throttle on downshift, except the computer does it for you. You need computer controlled throttle valves (ride by wire) to make it work. The gen 4 didn't have that capability, and the gen 5 doesn't have it without the software reflash.
#WordCrimes
SkyDork is offline
post #9 of 49 Old 11-29-2016, 05:41 AM
What do you know about the Schnitz flash. Will any of theses flashes effect the abs. Thanks for your input .
post #10 of 49 Old 11-29-2016, 08:11 AM
SkyDork's Avatar
The Schnitz is just a standard mail-in flash to derestrict the bike. They may also add some generic fueling changes. It's cheap and no one has had their ECU fried by them that I'm aware of.
The ABS module is separate from the ECU.
#WordCrimes
SkyDork is offline
