Gen 4: 2011-2015 Wheel compatibility - Page 5 - Kawasaki ZX-10R.net
 2Likes
post #41 of 70 Old 01-08-2014, 01:49 AM
tasos's Avatar
Originally Posted by theatiss View Post
what about putting a gen 4 rear wheel to a gen 3???
Gen2,3,4 front wheels are the same.
Gen1,2,3 rear wheels are the same.
No..
tasos is offline
post #42 of 70 Old 01-08-2014, 10:09 PM
Zr1
Zr1's Avatar
Good info here!
CMRA #713
Zr1 is offline
post #43 of 70 Old 01-09-2014, 12:05 AM
Always On Mod
Animal11's Avatar
It won't be a direct bolt on, but it may be able to fit with some mods.
The holes in the gen 4 swingarm that the axle passes through are ~25.4mm and the axle is 24mm.
So, the gen 3 swingarm would have to have 25mm holes. And then the rear caliper bracket would need to be bored out to 25mm. The gen 4 caliper bracket may work
Animal11 is offline
post #44 of 70 Old 01-09-2014, 08:49 PM
jdub669's Avatar
just sleeve the bearings down to 20mm form 25mm same length as the width of the 2 bearings. run the gen 3axle and blocks and youre good to go
"mechanical engineers build weapons, civil engineers build targets"
jdub669 is offline
post #45 of 70 Old 01-09-2014, 09:49 PM
Always On Mod
Animal11's Avatar
That's a good call. I'd say run a sleeve through the entire wheel though, cause there are 3 bearings and some internal spacers
sent from the mobile
Fast parts, Great Service: PM Mike at Rider's Discount
Animal11 is offline
post #46 of 70 Old 01-10-2014, 02:32 AM
theatiss's Avatar
:thef inger_red: _red:
Gen3 : Arata full exhaust , KN air filter , 520 DID Renthal , oem Ecu converted to Race Kawasaki Ecu , milled ported head , Kent camshafts , lowered , Pk shifter , 14k rev limiter . Ecu tuned by TRE ( mr Balogiannis)
http://www.youtube.com/watch?v=eLsF4A1k_ew
theatiss is offline
post #47 of 70 Old 01-10-2014, 05:11 PM
jdub669's Avatar
you could do that. i meant the actual wheel from bearing to bearings because i think my gen 3 had a spacer that sat in between the carrier bearing and the wheel bearing that had shoulders to allow preload to be applied to the wheel bearing on the carrier side but yea i guess you could just run it the entire length of the wheel/carrier combo.
jdub669 is offline
post #48 of 70 Old 01-11-2014, 04:32 AM
theatiss's Avatar
And something else
does the rear disc brake fit from a gen 3 to a gen 4???
theatiss is offline
post #49 of 70 Old 01-11-2014, 08:23 AM Thread Starter
ZX-10R enthusiast
dudewhrsmybike's Avatar
And something else
Yeah, they're all the same. Pretty sure they are same from 04-14 10R and 05-14 ZX-6R, maybe even a few other models.
Strictly for my Ninjas
2011 ZX-10R ABS
17/41, Woolich Racing Tuned ECU and QS, Rifleman's 1/5th throttle insert, CL XBK5 pads, Yosh case sliders, Mivv Carbon w/ Ti Akra link
dudewhrsmybike is offline
post #50 of 70 Old 01-11-2014, 02:50 PM
jdub669's Avatar
:mod_smilie_+1: on the zx10rs not sure on the zx6rs, but would make sense
jdub669 is offline
