Gen 4: 2011-2015 Wheel compatibility - Page 4 - Kawasaki ZX-10R.net
 2Likes
post #31 of 70 Old 08-05-2013, 08:21 PM
Dain's Avatar
I like where this thread is going!
Dain is offline
post #32 of 70 Old 08-05-2013, 08:24 PM
Tech5's Avatar
what is the weight of each rim for years???
The Truth
Tech5 is offline
post #33 of 70 Old 08-05-2013, 09:51 PM Thread Starter
ZX-10R enthusiast
dudewhrsmybike's Avatar
I will bring the digi scale with me tomorrow when I go to get my PP3's mounted...front and rear will be weight of wheel + bearings + rotors + bolts + speed sensor discs
05 ZX-6R front wheel and 04 ZX-10R rear wheel....
Strictly for my Ninjas
2011 ZX-10R ABS
17/41, Woolich Racing Tuned ECU and QS, Rifleman's 1/5th throttle insert, CL XBK5 pads, Yosh case sliders, Mivv Carbon w/ Ti Akra link
dudewhrsmybike is offline
post #34 of 70 Old 08-05-2013, 11:57 PM
ninjasaki's Avatar
To me the gen4 wheels looks the heaviest out of the past gens.
ninjasaki is offline
post #35 of 70 Old 08-06-2013, 08:02 AM
Tech5's Avatar
Not to mention,they look like suzuki wheels!!!!
The Truth
Tech5 is offline
post #36 of 70 Old 08-06-2013, 09:59 AM
I don't like the way they look at all. :headshake
F SANE IL is offline
post #37 of 70 Old 08-06-2013, 11:21 PM Thread Starter
ZX-10R enthusiast
Originally Posted by Animal11 View Post
I didn't get a spacer made for the caliper bracket yet. I tried pushing it down all the way and couldn't get the caliper to crash into the rotor, but I want to get a spacer made so it can't float.
By spacer, do you mean insert? Shit, if you get one made, have them make a few, I'd take one. I had clearance problems with the spacers while trying to install Gen1 rear wheel tonight.... so I put the Gen1 rear wheel on with the cush drive and spacers, but not caliper bracket. I mocked it up and determined that the the rotor side spacer was about 3/16" too tall, did you run into the same problem?
2011 ZX-10R ABS
post #38 of 70 Old 08-07-2013, 10:02 AM
Always On Mod
Animal11's Avatar
yes, i mean an insert to go from the G1 20mm axle to the G4 25mm caliper bracket.
I didn't have any fit issues using the cush drive and spacers all from the G1 wheel. Are you sure the rubber pieces inside the drive are the right side up? The little nobs on them can space you out too far if not.
Animal11 is offline
post #39 of 70 Old 08-07-2013, 12:25 PM Thread Starter
ZX-10R enthusiast
Yeah I installed the Gen1 wheel just as the way it came off the Gen1 swingarm but that rotor side spacer was too tall
Sent from Motorcycle.com App
2011 ZX-10R ABS
post #40 of 70 Old 01-07-2014, 03:27 PM
theatiss's Avatar
what about putting a gen 4 rear wheel to a gen 3???
Gen3 : Arata full exhaust , KN air filter , 520 DID Renthal , oem Ecu converted to Race Kawasaki Ecu , milled ported head , Kent camshafts , lowered , Pk shifter , 14k rev limiter . Ecu tuned by TRE ( mr Balogiannis)
http://www.youtube.com/watch?v=eLsF4A1k_ew
theatiss is offline
