Gen 5: 2016 -> What's best to upgrade first? - Page 3 - Kawasaki ZX-10R.net
 7Likes
post #21 of 27 Old 02-08-2018, 05:09 PM Thread Starter
More than likely I'll be below the 11k rpm range most days.
Xcretions is offline
post #22 of 27 Old 02-08-2018, 05:11 PM Thread Starter
Originally Posted by ZX10RArcher View Post
Top end, peak power is going to be within 1HP of each other - so negligible.
Here is a gif cycling the differences between the full system and their slip on with their link pipe.
Attachment 411986
Question you need to ask yourself is how long will you and the bike spend time at that max power RPM right after 13000 RPM? Are you and the bike going to spend more time there... or are you going to spend more time below say 10000-11000 RPMs?
More than likely, I'll be around or below the 11k rpm range most days.
post #23 of 27 Old 02-08-2018, 09:25 PM Thread Starter
Attachment 411986
The looks of this, it looks like the link with slip on is pretty competitive to the full. Am I reading it wrong?
post #24 of 27 Old 02-08-2018, 10:09 PM
Its a really tough call if you just look at them overlayed like that; was meant as a quick comparison only. You really have to overlay them in photoshop. First you line up the stock HP runs, ignoring the torque curve; you can then see the differences where one outperforms the other in HP. You then have to do it again for TQ and line up the torque curve while ignoring the HP curve and compare them that way for torque. You can't just overlay them like I did in the animated GIF since the scaling is off between the two PDFs of their charts.
I'm not here to push you one way or the other, ultimately it is your money. But for me it was well worth it especially since I haven't had to mask the low end weakness by regearing my 5th gen (still 17/39). I can pretty much gas it in 6th gear cruising around town and have no bog or have to downshift to get into the power. All the claims Akra has made about their gains were there and then some and I backed it up in my own dyno testing as shown in the link posted earlier.
Again, look at data from several areas, not just mine or what I present. I had various slip ons on my 4th gen before putting a full on - no comparison whatsoever. Had I just put the full system on from the get go like I wanted I would've been way happier. On my 5th gen, I wasn't going to make the same mistake again so as soon as Mike @ Riders Discount was taking orders for the Akra Evo, I gave him my wallet and had one of the first few in the country. Don't regret it one bit either.
You can always buy the slip on and upgrade to the full later on. Or you can get the Graves slip on and then upgrade just the header later on too with their Link system or whatever they call it.
ZX10RArcher is offline
post #25 of 27 Old 02-26-2018, 06:25 PM
Good assessment. I recommend reducing front sprocket to 16. It will really give you the kick needed in the mid ranges without getting overly torquey. Dirt cheap to mod and makes a big impact to performance.
Raja Segar is offline
post #26 of 27 Old 03-24-2018, 05:29 PM
meanstreak5's Avatar
Iam looking to get an akra slipon but cant find a midpipe from akra, are you saying graves makes a midpipe that will work with akra can for gen 5? thanks
2000 WR400 SM, 2004 KTM 300EXC, 2005 1800 Wing, 2006 ZX10R, 2017 ZX10R
meanstreak5 is offline
post #27 of 27 Old 03-26-2018, 01:24 AM
I recently changed mine to 16/41. RPM is higher now and it is torquey only when you ride it aggressively. It feels like a completely new bike.
Acceleration is crazy.
