Valve Clearance Philosophy - Page 2 - Kawasaki ZX-10R.net
post #11 of 23 Old 12-12-2006, 12:17 AM
AZ06ZX-10R's Avatar
Images: 7
Middle to loose
Middle to loose is best IMHO. Tight is not best because it's critically important that the exhaust valve seats fully to allow for heat dissipation into the cylinder head. Hard to believe but if the exhaust valve is too tight when the motor is running hot(full operation temp.)it will not fully seat properly and the result could be a burnt exhaust valve. That's why it,s sometimes normal for racing engines to have valve train clicking noise at low speed to be sure the valve face has that precious time to contact the valve seat and dissipate some of the 3400 degree combustion temp. A motor runs and sounds like crap with a burnt valve so I don't think it's worth the risk to go tight. A burnt valve sounds like an exhaust leak,without the exhaust leak:headshake
AZ06ZX-10R is offline
post #12 of 23 Old 12-13-2006, 06:30 AM Thread Starter
Thanks for the feedback, everyone. I've always adjusted at the looser end of the range, but thought it might make for some interesting opinions. Time to get to work this weekend...
CanyonCarver is online now
post #13 of 23 Old 01-03-2007, 06:13 PM
CFH
valves
while installing a high flow air filter i thought i would take a look down the throttle bodies with a flash light. i saw that what i believe is the valve had a black ring around the outside of the valve base seated end ???? is it o.k. 2400 miles 06
CFH is offline
post #14 of 23 Old 01-03-2007, 10:39 PM
FAF
Rent this space
Picture ??
FAF is offline
post #15 of 23 Old 01-04-2007, 06:47 AM
BANNED
That is carbon build up. Somethin' like BG 44K or runnin' Chevron gas will get rid of it.
swjohnsey is offline
post #16 of 23 Old 01-04-2007, 11:28 AM
CFH
carbon build up
cool thanx,
CFH is offline
post #17 of 23 Old 09-11-2017, 06:31 AM
ZX10's Avatar
Originally Posted by Dukester View Post
If you set them to the loosest spec you will loose some top end and pick up some mid range.
If you set them to the tightest spec you will trade some mid range for top end.
If you want to go with either of the two extremes exactly you will need to make some shims in custom sizes.
Is there a benefit / difference performance wise for being exact like setting all 16 valve clearances to the exact same number? Say for example 0.20mm for all and not settle for 0.19 or 0.21?
ZX10 is offline
post #18 of 23 Old 09-11-2017, 07:31 AM
badassjake's Avatar
closer to loose.
badassjake is offline
post #19 of 23 Old 09-11-2017, 08:25 AM
The valve clearance with the run of the kilometers, get every day thigter, because the valve gets into the cylinder head.
So it is better to have them closer to loose limit than have it closer to tight limit.
My opinion is to have them from the middle, to the closer limit.
coyote9mm is offline
post #20 of 23 Old 09-11-2017, 08:31 AM
Newf's Avatar
2016 zx10r Racekit manual recommends 0.20mm on both intake and exhaust.
Name:	ImageUploadedByMO Free1505136629.856671.jpg
Newf is offline
