Trading money for weight - Page 67 - Kawasaki ZX-10R.net
 174Likes
post #661 of 709 Old 02-09-2018, 02:26 PM Thread Starter
peterd10r's Avatar
Images: 7
Lun47 that would be very hard to do!and yes mirrors and all road spec gear was on the bike!it stands to reason the power to weight ratio has changed significantly so we all no what that means!faster acceleration!quicker changers of direction and a much shorter stopping distance!Im not quite sure with your comment on the bikes C.O.G!the engine hasn't moved in any direction!just everything else has been replaced withe Carbon Fiber and Titanium
peterd10r is online now
post #662 of 709 Old 02-11-2018, 04:00 AM
Theres still more weight to come off your bike then. Mirrors. Side stand. Ohlins preload adjuster seems unneccesary to carry around all the time. Once its set for your weight theres no need to adjust it unless your doing track riding too.
I removed my horn as a blip of the throttle is louder than the horn.
How about fitting a 180 rear tyre? Its now less than a 600 weight so you can run a 180 ok.
Plus one more trick... fill the tyres with helium lol
peterd10r likes this.
ukzx10r is offline
post #663 of 709 Old 02-12-2018, 03:20 AM Thread Starter
peterd10r's Avatar
Images: 7
You no what I want to remove!my ABS unit!I can't find a way to stop all the fault lights and codes if I remove the unit!I wish there was something like the exhaust servo buddy that can by-pass the ABS wiring plug!Im pretty sure that unit would weigh around a kilogram!Ive called at least 20 service stations trying to find a place that sells helium for tyres and most have hung up in my ear!I might try a party shop as some have bottles of helium for balloons!I will let you how it pans out............
ukzx10r likes this.
post #664 of 709 Old 02-12-2018, 05:00 AM Thread Starter
peterd10r's Avatar
Images: 7
ABS unit removal
Well I just contacted Gilles who is in Australia training business owners on using the Dimsport Rapidbike fuel modules!bike electronics is what he specialisers in and I explained my situation with removing the ABS unit and sent him the wiring diagram!he sounded very positive and is going to get back to me so my fingers are crossed!
post #665 of 709 Old 02-14-2018, 04:06 PM
Peter have you seen these lightweight reseviors?
You stick them on the back then use the standard back one on the front to save weight.
Very cheap mod.
https://rover.ebay.com/rover/0/0/0?m... 162805846497
ukzx10r is offline
post #666 of 709 Old 02-14-2018, 04:15 PM
Capncalyx's Avatar
Very cheap mod.
Nah, not that one! This is the one you want mate!
https://www.kurveygirl.com/shop/prod...bopjsmaumu4cu6
Just ordered this from her and she ships fast. Im going back for the Bridgeport 83 deg valve stems soon.
peterd10r and Boxtradamus like this.
*Official winner of one Riflemans 1/5 insert
Also known to frequently drink and post.
Capncalyx is offline
post #667 of 709 Old 02-14-2018, 04:54 PM
Very cheap mod.
Complete garbage!
and YES, he has seem em
Boxtradamus is offline
post #668 of 709 Old 02-15-2018, 01:51 AM Thread Starter
peterd10r's Avatar
Images: 7
UK don't waste your money mate!the fu.king things seep brake fluid after 4 weeks!LDH and I think Box warned me but I'd already pulled the trigger!Tygon tubing is the only stuff that works as Captncalyx stated!the genuine Honda ones on fleabay are crap!actually worse than crap!
post #669 of 709 Old 02-15-2018, 01:57 AM Thread Starter
peterd10r's Avatar
Images: 7
And on the ABS unit!there is no quick fix!change the loom to a non-ABS loom is the answer!there is a lot going on with ABS over a non-ABS!
post #670 of 709 Old 02-15-2018, 03:40 AM
Thats odd. My dad had this on his r1 with no bother.
Wasnt sure what you had fitted to your bike as theres so many pages that i couldnt find photos of its current spec
ukzx10r is offline
