Trading money for weight - Page 62 - Kawasaki ZX-10R.net
 107Likes
post #611 of 615 Old 01-11-2018, 05:05 PM Thread Starter
peterd10r's Avatar
Images: 7
You funny fu.k!no such thing as ugly mate!we are all unique in our own way!if we all looked the same eating rice would become a challenge!no offence ment here I just find it hard to distinguish one from the other sometimes!
peterd10r is offline
post #612 of 615 Old 01-16-2018, 02:24 PM Thread Starter
peterd10r's Avatar
Images: 7
7075 Aluminium rear axle weight
Well here's the weight difference between the oem steel axle and the 7075 Aluminium axle!for interest sake the outside diameter of the oem steel axle is M25mm!the 7075 obviously has a M25mm diameter with a internal 13mm hole!so the outer wall thickness is 6mm!the front specs are not far away
ID:	410729   Click image for larger version
ID:	410737   Click image for larger version
post #613 of 615 Old 01-16-2018, 05:47 PM
Not bad weight.
The 7075 is harder to machine than lesser alloys. I have machined 7075 bits myself for my bike.
Its quite heavy for an alloy too but strong.
My main concern would be the threads on the rear axle.
But you could keep a check on the nut with a torque whench from time to time.
Ideally titanium would be the best option because you could go thinner wall than standard yet keep the strength but its expensive.
Then you could get it under 50% weight.
peterd10r likes this.
ukzx10r is offline
post #614 of 615 Old 01-17-2018, 01:50 AM Thread Starter
peterd10r's Avatar
Images: 7
Titanium maybe 40%!I have not yet seen 1 piece of Titanium hardware with the same dimensions as oem 50% lighter!thats even with a Racespec drilled for safety wires Titanium bolt!the walls would have to be pretty thin to drop that much weight as the oem isn't that thick at all
post #615 of 615 Old 01-17-2018, 05:14 AM
Genuine grade 5 is 55% of steel.
When i made my shock mount i put bigger hole down the center and made all walls thinner in every dimension so i could beat the 55%.
This would cost alot to make spindle in grade 5 though
ukzx10r is offline
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
