Gen 5: 2016 -> spec differance R vs RR - Kawasaki ZX-10R.net
 1Likes
post #1 of 18 Old 10-30-2017, 05:24 PM Thread Starter
Send a message via Skype™ to halfswede
if i read the marketing text, than the 2017 RR have:
trackfocused gear ratio (2nd to 6th shortened)
M50 Brembo
and lightweight marchesini wheels
if i compere the tech specification on kawasakis USA hompepage and on the german Kawa homepage, than i am suprised:
1. The simple R has exactly the same gear ratio in every gear
2. the simple R has the same M50 Brembo Calipper and same Brembo zylinder
3. even the weigth is the same 206 kg for both R and RR (only the simple R without ABS is 204 kg)
the gear ratio numbers i even controlled today in a service manual, i was shocked but all article number is the same for all gears in the simple R and also in RR
What is the TRUTH ????
thanks
Gabor
halfswede is offline
post #2 of 18 Old 10-30-2017, 06:33 PM
Victors's Avatar
Wheels and material in the engine for extra strength and clearance for larger cams. The autoblip is enabled on the DR too, which can be turned on through the ecu in the R. Otherwise it's the same bike.
Edit.. oh and don't they come with the super corsa tires?
2013 10R
2007 650R
2016 10R
Victors is offline
post #3 of 18 Old 10-30-2017, 06:55 PM Thread Starter
Thanks
How could the weight be the same while the marchesini wheels are much lighter and no backseat, no footpeg back ????
The RR should be lighter.....
Why do they promiss in the RR adds trackfocused gear ratio when the simple R has it also???
post #4 of 18 Old 10-30-2017, 11:53 PM
Victors's Avatar
Extra material in the engine adds weight
2013 10R
2007 650R
2016 10R
Victors is offline
post #5 of 18 Old 11-01-2017, 12:02 AM
Newf's Avatar
Originally Posted by halfswede View Post
Thanks
RR wheels are not lighter than the R wheels.
Newf is offline
post #6 of 18 Old 11-01-2017, 12:43 AM
Newf's Avatar
Material has been added in some area but also shaved off in other area...
Newf is offline
post #7 of 18 Old 11-01-2017, 02:34 PM Thread Starter
Thanks
suprised about the marchesini, is it really same weight?
i have the 2017 eurpean zx10RR.
Somewhere i read, if i change the sprocket, the RR ECU or IMU do not need an ecu flash, it is selfadjusting, is it true?
Is it even selfadjusting if i put a de-cat pipe and a Slipon on it? Or i must atliest remap?
GAbor
post #8 of 18 Old 11-01-2017, 05:51 PM
Victors's Avatar
Sprockets dont need any changes. There are wheel speed sensors.
You can change exhaust withoit having to remap but it will help with power etc.
halfswede likes this.
2013 10R
2007 650R
2016 10R
Victors is offline
post #9 of 18 Old 11-29-2017, 11:39 PM
I believe the RR also has an adjustable swingarm pivot. A tuning tool that is very useful if you know what you're doing. Kinda like adjustable offset yokes. Very useful if you know what you're doing. Very dangerous if you don't.
Gunner is offline
post #10 of 18 Old 11-30-2017, 03:28 AM Thread Starter
Are you shure? I never read this anywhere....
