Gen 1: 2004-2005 Rifleman 1/5 Revised Install For 05 ZX10R W/Pics - Page 2 - Kawasaki ZX-10R.net
 1Likes
post #11 of 83 Old 01-19-2012, 04:00 PM Thread Starter
ZaleZ's Avatar
Yeah, I understand that there are allot of people out there that did not or do not need to get under the tank. I probably did not need to, but after testing it both ways, it felt a little tighter after I did shave a little off the cable. Just some info for the ones that do. Thanks everyone.
ZaleZ is offline
post #12 of 83 Old 01-19-2012, 04:42 PM
Of course you are faster
Rifleman's Avatar
thanks dude, this has been added to my signature list of links on install. Very comprehensive, lots of pics and detail..
perfect.
Need to know how to install your Rifleman's 1/5th throttle insert? click me
For more info on a sticky grip (not enough cable slack) click me
And another amazing install write up click this
Originally Posted by Rifleman View Post
lol, once you go 1/5th... you NEVER go back
Rifleman is offline
post #13 of 83 Old 01-19-2012, 05:31 PM Thread Starter
ZaleZ's Avatar
perfect.
Thanks Bro. Took two days to write. Did it from memory. Then had my wife read it and see if she could follow it. She is not mecanicaly savvy and was able to
ZaleZ is offline
post #14 of 83 Old 02-03-2012, 09:53 PM
bluedevil's Avatar
Sorry ZaleZ it took so long your Thread should have been Cemented in the "How TO" sections for many reasons it got missed by some Mods....no worries better late than never.
Thanks for your time also moved to the performance and tech section as well.
bloo
____________________________________________
Sent from My Computer via DSL mid to low service Firefox updated version, sometimes wireless sometimes Wire from the garage depending on connection speed.
bluedevil is offline
post #15 of 83 Old 02-03-2012, 10:00 PM Thread Starter
ZaleZ's Avatar
bloo
Thanks Bro
96 Suzuki Bandit (Torn Apart, Chopped Up And Rebuilding, Rat Bike)
05 ZX10R Raw Titanium/Black
My Write Ups
Gen 1 04/05 Rifleman 1/5 Install With Lots Of Pics http://www.zx-10r.net/forum/showthread.php?t=110851
My Site: https://sites.google.com/site/zalezbuilds/
ZaleZ is offline
post #16 of 83 Old 02-03-2012, 10:52 PM
Flipr's Avatar
Well done to the OP!! Comprehensive write up on how ANYONE could fit one of Rifleman's inserts. Rep sent.
Area P slip-on & link pipe,De-catted Headers,PCV & Autotune,Ivans block off plates,K & N filter,X-Tre,Driven Superlite sprockets,+2 rear,stock front,520 conversion,V4 Speedohealer,Servo motor eliminator,Re-valved Ohlins damper,Spiegler front brake lines,Zero Gravity SR dark smoke screen,Stompgrip tank pads,ZX-6 rear cowl,and more to come.
Speed dosen't kill,it's the sudden stop!!!
Flipr is offline
post #17 of 83 Old 02-29-2012, 07:26 PM
cswerner's Avatar
got mine in just now, no test ride yet. didnt get under the tank, didnt cut any of the lock nuts. It seems to snap closed like normal from what I can remember, seems a little harder to crank the throttle, but Im guessing thats normal. Will have to see how it acts when running. Thanks for the write up!
cswerner is offline
post #18 of 83 Old 02-29-2012, 07:42 PM
Post Whore
-Op-'s Avatar
should not really feel much harder. It should be basically like stock except shorter. Try adjusting your cables a little bit and see if itll be easier. Test it in multiple throttle positions. It should snap back whether you give it 10% 20% 50% 100% throttle very easily.
-Op- is offline
post #19 of 83 Old 02-29-2012, 08:01 PM
cswerner's Avatar
Would clipping the lock nuts on the throttle cables by the handle bars and adjusting them out further make it easier to roll?
cswerner is offline
post #20 of 83 Old 02-29-2012, 08:03 PM
Post Whore
-Op-'s Avatar
yeah it does. I ditched the lock nuts on mine under the airbox as well as the forward ones to get more slack. try it and see what happens. Shouldnt be any binding though.
-Op- is offline
