Results from Individual Cylinder Tuning - Page 3 - Kawasaki ZX-10R.net
 15Likes
post #21 of 26 Old 11-25-2017, 12:32 PM
Originally Posted by Victors View Post
I'd be interested to know what the air fuel is for each cylinder on a stock or near stock setup between a few bikes to get an idea if they are end up being similar from the factory. Like if cylinder number 2 is lean and cylinder 4 is rich compared to the others etc
I reckon it's going to vary wildly bike to bike. You may see some tendencies, but nothing where you can say something with a certain amount of confidence like "oh on this motor for this bike cylinders A and X on this bike run this much rich and B and Y run this much lean." You'll likely be able to see that a particular cylinder has a tendency to run rich/lean in comparison to another, but there are too many variables at play where you'll be able to say that it runs within a certain percentage window.
For those that are interested in doing this but don't want to weld four different wideband bungs on their header pipes, we use a kit similar to this:
Works by putting in a rivnut in each header pipe that you move the sample block to when gathering data. You then just move the sample block pipe to pipe to pipe to pipe and correct as you go. Then when done sampling a cylinder, just put in the screw and copper washer. Would work great with the new WRT Auto Tune Live feature ;)
ZX10RArcher is offline
post #22 of 26 Old 11-25-2017, 12:55 PM
Ron Mears's Avatar
Originally Posted by ZX10RArcher View Post
Nice work.
We picked up huge gains on a 2012 recently done before the race season. Testing/tuning methodology was the same as yours - nothing crazy used, simply the WRT software tuning per cylinder, dyno and lots of time to create individual maps for each cylinder.
From his last tune (combined AFR across all four) it put down a typical and respectable 184-185 to the wheel. After observing, tinkering and finally getting down to business tuning per cylinder, he picked up 10 extra horses putting him in the mid 190s. All on pump gas mind you. We then did another tune for him, this time on race gas and yeah, bike is a monster. We had great results doing this on a ZX-6R as well.
Tuning per cylinder is something that is often overlooked because of the cost since we have to make pretty much four complete maps for each individual cylinder. But for race purposes where the difference between standing on the podium and off of it are a fraction of a second and any advantage you can get makes it worth the extra cost. Good job.
-A
What's the ballpark cost on such a tune and the lead time necessary?
Ron Mears is offline
post #23 of 26 Old 11-25-2017, 01:45 PM
mpp12's Avatar
Anthony is there a pic...
Im not familiar with the process.
thanks
mpp12 is offline
post #24 of 26 Old 11-28-2017, 03:16 AM
What were the final numbers compared to when it came in for HP/Tq?
LampPost is offline
post #25 of 26 Old 11-29-2017, 10:37 AM
Great Information! Thanks for Sharing!
-Randy
RANDYR41 is offline
post #26 of 26 Old 12-18-2017, 04:50 PM
993twin's Avatar
Yassou, Vre! Definitely cool stuff...thanks for sharing!
993twin is offline
