PC map postings - Kawasaki ZX-10R.net
 2Likes
post #1 of 230 Old 04-14-2005, 06:05 PM Thread Starter
Ground Zero's Avatar
Images: 7
PC map postings
This thread will be for MAPS ONLY!!!!! If you have a map you would like to share please send me (Tread70) a PM or email it to me @ tread70@comcast.net All maps will need a brief description of mods and year, make , and model.
Thank You,
Tread70
Edit:Added Gillman's map to first post
Custom Map for 2006 ZX-10r w/Akrapovic Evolution Race full exhaust system & K&N Air filter
Edit 10//19/2008 by Bluedevil
Here is the link for "Map Requests and Discussions" as we are trying to keep Sticky s to Min.
Map Request and Discussions
Thanks,
bloo
File Type: zip Muzzy Full & BMC Street.zip (994 Bytes, 1598 views)
File Type: zip Muzzy Slipon.zip (1,000 Bytes, 1405 views)
File Type: zip ZX-10r Gilley.zip (867 Bytes, 1163 views)
File Type: zip 11BigDaddys_Map ZX-10.zip (1,014 Bytes, 881 views)
Ground Zero is offline
post #2 of 230 Old 04-15-2005, 03:39 PM
BNninja's Avatar
Send a message via Yahoo to BNninja
Tested teh Kyle map I hybrided it is really good.
I was doing all 4th gear roll-ons from 4500rpm to redline in the throttle increments.
At 60-80-100 the rear tire was struggling for grip.
I went back home and richened it up once again in the 0-2-5 range...not time for a test but the back firing is almost gone before the second richening.
File Type: zip Chris_Hindle_Hybrid.zip (897 Bytes, 1083 views)
"Bikes are like women: beat them like a whore, they can take it and you will like the moaning you hear."
BNninja is offline
post #3 of 230 Old 04-26-2005, 09:53 AM
BNninja's Avatar
Latest version...i changed a lot in the 2-5-10-20 & 8-100 to make it match the a/f ratio I guessed from viewing my charts...someone try it as it will rain here for two more days and has been cold.
File Type: zip Chris_Hindle_v3.zip (886 Bytes, 829 views)
BNninja is offline
post #4 of 230 Old 04-27-2005, 11:54 AM
BNninja's Avatar
I think the 10r is running weak for everyone when fully warmed up which means that the ECU is richening the circuit too much and we are all getting crappy power and power delivery. All I know is my bike is crazy under 190 degrees, above 202 it is a dog, feels like i'm back with the 17T front sprocket.
Anyways, I made more changes in top end of 100% throttle, 0-2-5 40-60 & 80 also. I compared my map to GZ's (after my changes) and they are suprisingly close in most areas. Mine is alway leaner below 4500 rpms then I think mine get a little richer than his. I tested v3 yesterday and it felt strong so I'm hoping v4 will be even better since before I had made no changes to 40-60% throttle.
File Type: zip Chris_Hindle_v4.zip (870 Bytes, 932 views)
BNninja is offline
post #5 of 230 Old 05-04-2005, 04:48 AM
K10
K10's Avatar
hope you don't mind DustinR
Here is DustinR's map
File Type: zip DUSTINmap_current.zip (738 Bytes, 1193 views)
K10 is offline
post #6 of 230 Old 05-18-2005, 02:37 AM
den
den's Avatar
try my map position for me on pcusb is low:0
mid:0
high: -2
enjoy it, home mademap, no dynocenters here
File Type: zip den 7.zip (884 Bytes, 804 views)
den is offline
post #7 of 230 Old 06-05-2005, 07:34 PM Thread Starter
Images: 7
Summer MAP
Here is my Summer MAP done last Aug for the Muzzy Full/BMC combo. I find that my bike runs better/cooler with the Summer MAP in 85+ degree/humid weather. The MAP was done by the same tuner,same dyno,same setup but at 90deg shade temp. The original MAP I posted was done at ~50deg temp in Dec. Winter MAP was giving me some knocking under heavy load. I use to jet my 9 the same way...50 swing in air temp can change things a bit. Just thought I would share...
File Type: zip Muzzy Full & BMC Street- Summer.zip (890 Bytes, 818 views)
post #8 of 230 Old 06-12-2005, 08:11 PM Thread Starter
Images: 7
Here is a MAP averageing the 2 cusoms I had done. Ran this MAP this weekend and it ran great. Not much difference between the 3 full systems maps, as you can see, but none the less someone migh benefit from it.
File Type: zip Average.zip (844 Bytes, 690 views)
File Type: zip Muzzy Full & BMC Street - Winter.zip (1,012 Bytes, 644 views)
File Type: zip Muzzy Full & BMC Street- Summer.zip (890 Bytes, 637 views)
post #9 of 230 Old 08-16-2005, 06:20 PM
GOTCHY's Avatar
well guys after playing around with some slip on maps i reckon i have found a good compromise all around for fast street riding and a acceptble mpg ratio so if someone want to try it and give me some feedback would be good
ps: this was tested on a european 2004 zx 10r with a yoshimura trs near sea level
File Type: zip Rick 2.zip (860 Bytes, 874 views)
GOTCHY is offline
post #10 of 230 Old 08-19-2005, 06:46 PM
MILLENNIUM FALCON's Avatar
Images: 13
Thumbs up
Here is a map tuned for a Akrapovic Evo II and BMC Race Filter. I got my bike tuned at a local shop. Let me know what you think after you try.
File Type: zip Custom Map BMC 2.zip (888 Bytes, 1381 views)
MILLENNIUM FALCON is offline
