PC map postings - Page 5 - Kawasaki ZX-10R.net
 2Likes
post #41 of 229 Old 09-21-2011, 01:32 AM
DAXENOX's Avatar
Images: 11
Send a message via Skype™ to DAXENOX
maps for ecu racing ?
.est
italian official tester
DAXENOX is offline
post #42 of 229 Old 09-26-2011, 12:00 PM
Map for TBR and K&N race filter
'09 ZX10R
TBR slip-on
PC3 USB
K&N race filter
Anyone have a map for this set up?
Chuck84 is offline
post #43 of 229 Old 09-26-2011, 10:34 PM
Maps for Two bros slip on n K&N filter for a PCV on a Gen 3
30_degrees08 is offline
post #44 of 229 Old 10-05-2011, 06:27 AM
zuhayr's Avatar
05 ZX10R custom map
Hi all
Here's a map for an '05ZX10R with a Growler, exhaust and secondary butterflies removed, and BMC airfilter, custom mapped at sea-level.
Zuhayr
Name:	air-fuel ratios1.1.jpg
ID:	153702   Click image for larger version
Name:	air-fuel ratios2.1.jpg
ID:	153703   Click image for larger version
Name:	air-fuel ratios3.1.jpg
File Type: zip 05 ZX10R Growler BMC exhaust and sec butterflies removed.zip (1.0 KB, 381 views)
Black/Green 2011 ZX10R
Black 2005 ZX10R, STOLEN
MRA double bubble screen, Fren Tubo braided hoses,
Ohlins steering damper, Brembo master cylinder,
Shogun frame sliders, BMC filter, Power Commander,
Growler end can, BT 016 sticky stuff, Pazzo shorties
zuhayr is offline
post #45 of 229 Old 10-05-2011, 09:52 AM
zuhayr's Avatar
forgot to say that the blue line was with a faulty fuel pump, the red line was with the PC map off their website (M212-015.djm) and the green line is the map I've uploaded
zuhayr is offline
post #46 of 229 Old 10-13-2011, 08:56 AM
aussiezx10r's Avatar
Hey all. I have an 08 gen3 zx-10r and a beet exhaust. Does anyone have a map for something similar to this?
aussiezx10r is offline
post #47 of 229 Old 10-15-2011, 12:09 AM
Yeah, it's in your inbox.
San
oldmansan is offline
post #48 of 229 Old 10-15-2011, 11:51 AM
San
You Sir are awesome.
Cheers,
post #49 of 229 Old 10-17-2011, 09:39 AM
TinMan_38's Avatar
Looking for a base map (pcIII) for 06 with stock filter, comp werkes gp side mount /cat delete( or comparable), and smog block offs. And can anyone tell me if the pc disables the fuel cut on closed throttle?
there are few problems in life that the proper application of throttle will not fix.:deathmeta
TinMan_38 is offline
post #50 of 229 Old 10-20-2011, 11:23 PM
Does anyone have a map for an 08 with akra slip on, pc3 and a k&n filter?
12yamaha is offline
