PC map postings - Page 3 - Kawasaki ZX-10R.net
 2Likes
post #21 of 230 Old 12-15-2006, 12:24 PM
fordfasterr's Avatar
Send a message via AIM to fordfasterr
Here is a good map that I am running with a yoshimura rs3 bolt-on (also works well with stock pipe) and bmc / tre / tps mod.
Must-haves for this map:
>> TRE <<
Enjoy !
AIM = fordfaster - 2004 CBR 600RR
fordfasterr is offline
post #22 of 230 Old 12-15-2006, 01:58 PM
Originally Posted by Hoser
thanks for the map. looks pretty good, might be a bit lean for me in a few spots on/off throttle but i'll give it a try.
my mods are yoshi trs bolt-on, K&N, TRE (gi pro) so its good for my setup, just not sure about elevation. im at 1100 ft here.
I would say that this map is 2 rich for you at 1100 feet...
The map I posted above is a richer version of the dan kyle tre sato slipon map... I used the sato slipon map with the stock exhaust and the BMC filter and the bike ran HARD ! The throttle is very crisp due to the leaner mixtures but I would not use it at higher elevation... Who knows for sure - I don't have an o2 guage hooked up to verify if it is too lean but it still felt good.
Try the other map, and if it seems to bog, try this one instead:
dan kyle sato slipon map
(user submitted map off the dynojet site it wasnt done with the TRE)
Lastly, don't forget to set your TPS range in the power commander.
You can do this easily by installing the 9v battery to the pc3, then use the tps utility to set the TPS range.
Good luck !
post #23 of 230 Old 01-31-2007, 10:44 AM
Gill Man's Avatar
Custom Map
PCIII Custom Map for 2006 ZX-10r w/Akrapovic Evolution Race full exhaust system & K&N Air filter.
Dyno results Stock = Max Power 165.7 Max Torque = 80
Dyno results w/Mod = Max Power 171.7 Max Torque = 81.7
ID:	27302   Click image for larger version
Name:	ZX-10R Dyno results.JPG
File Type: zip ZX-10r Gilley.zip (867 Bytes, 985 views)
Gill Man is offline
post #24 of 230 Old 03-11-2007, 01:53 PM
04 zx-10r Akro EvoII & a K&N bike made 171hp on a dj 250 with this custom map enjoy.
http://www.mediafire.com/?fazk5zntdqm
DareDevil is offline
post #25 of 230 Old 04-16-2007, 09:09 PM
MILLENNIUM FALCON's Avatar
Images: 13
Thumbs up
Originally Posted by DethsZX10 View Post
My engine spun a bearing so i swapped in a stock motor into my 05. The original motor had a MAP for my degreed cams and thin HG. This MAP has triggered my FI light and it runs pig rich. I need a MAP for my EVO2 for a stock motor. I had Ivan's Map originally but didnt keep it in my files. so i'm starting over from scratch. I didnt know how good the Map on Dynojets website was but i need a decent off the shelf map before i get it on the dyno later this summer. I don't run the TRE btw. Thanks!
Here you go enjoy!
File Type: zip Custom Map BMC.zip (889 Bytes, 692 views)
MILLENNIUM FALCON is offline
post #26 of 230 Old 07-22-2007, 11:09 PM
MIA Ex-Mod
Tread70's Avatar
POSTED FOR Nite-ryder
Here is a custom map that I had done this weekend. I have an '06 ZX-10 with Yoshi bolt-ons, BMC air filter, disabled butterfly valve, KLEEN block off plates, and gutted cats. I am running at about 4500 ft. elevation.
I think you're still puttin' these out!! Hopefully someone can benefit from it.
Thanks...
Nite-ryder
File Type: zip custom.zip (808 Bytes, 729 views)
2004 PBO zx10-r pazzo, seat cowl, yoshi Ti TRS bolt on, PC3, Speedo-Healer, Hyperpro, Braided lines, 16-40, Sato sets, ZG dark screen, and more.
Tread70 is offline
post #27 of 230 Old 08-04-2007, 10:27 PM
MIA Ex-Mod
Tread70's Avatar
POSTED FOR SalKhan
Just wanted to throw a custom map your way. This map is for 06 (and Iím guessing 07?) ZX-10Rís with A&R Motorsport Race Baffles and BMC Race Air Filter.
Everything else is completely stock!
Hope it helps!
SalKhan
File Type: zip zx10-2.zip (961 Bytes, 682 views)
Tread70 is offline
post #28 of 230 Old 01-31-2008, 02:18 PM
blackisfaster's Avatar
POSTED FOR blackisfaster
For 2006 ZX10R:
Posted this in performance and tech: and the pc map posting thread is closed, so I will post this here. It is a map for an A and R race baffle kit with a BMC street air filter. Hope someone can use it; and if anyone tweaks this and makes it better please re-post. Peace
File Type: zip zx10-race_baffle.zip (981 Bytes, 570 views)
A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort.
2006 ZX10R (Black)
blackisfaster is offline
post #29 of 230 Old 11-19-2008, 08:57 AM
MIA Ex-Mod
Tread70's Avatar
Posted for Older Guy Bazzaz Maps
There Bazzaz maps are for a 2008 ZX-10R with a flow through Area P full exhaust system.
The Apex 10-24 is for a dyno run and auto tune
+5 is to clean up some rough transition from off throttle to on throttle.
+10 is same a bit better...
Older Guy
Tread70 is offline
post #30 of 230 Old 07-08-2011, 01:14 PM
BAYBOI's Avatar
lets share those maps fellas lol
bay boi get wit it or get lost
BAYBOI is offline
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
