PC map postings - Page 2 - Kawasaki ZX-10R.net
 2Likes
post #11 of 229 Old 08-31-2005, 04:31 PM
dpower's Avatar
Muzzy Full System, Stock air filter map
I got this map from Muzzys for their Ti full system using a stock air filter.
File Type: zip ZX10fullsystem.zip (816 Bytes, 709 views)
dpower is offline
post #12 of 229 Old 09-13-2005, 07:38 PM Thread Starter
Ground Zero's Avatar
Images: 7
After spending the past couple of months fine tuning my custom MAPs, based on real world riding conditions, I have got one that really feels great. The only real change from the custom map was in the 3750-5000rpm range where I added a little more fuel. Really runs smooth and cool at cruising speeds & pulls like a freight train . Running temps (highway) are down 10-15 deg. Here is the map if anyone is interested...
File Type: zip Muzzy Full-BMC-Final.zip (887 Bytes, 1019 views)
Ground Zero is offline
post #13 of 229 Old 04-02-2006, 10:03 AM
10 speed's Avatar
another attempt
File Type: zip map dyno.zip (854 Bytes, 758 views)
I got tiered of buying go fast parts.... So i got a turbo! now i need go slow parts!
If it aint modded it aint yours!
10 speed is offline
post #14 of 229 Old 04-27-2006, 01:01 AM
coach's Avatar
Here is a custom Fuel and Ignition map for a European model ZX-10r using standard unleaded fuel. Bike has Akrapovic Slip-on can with baffle removed, Factory Pro Velocity Stacks and a BMC Race Air Filter. My bike was recorded at 164.38bhp and 83.06ft/lb of torque with this set up. Hope this is useful to someone else who is struggling to find a map for their Ignition Module.
File Type: zip ZX10 FW.zip (950 Bytes, 915 views)
Not enough room here to list everything.
coach is offline
post #15 of 229 Old 08-12-2006, 09:19 PM
jrsjkd's Avatar
Arata FULL system with BMC
BTW, I have been switching back and forth between these maps and I have the Ti slip-on. Best maps ive found so far, but I think for me I will need to blend the two together a bit.
There is no spoon...
jrsjkd is offline
post #16 of 229 Old 08-21-2006, 02:30 PM
mace's Avatar
Images: 32
My map is for a European '04 model with a Laser Hotcam slip on and a DNA aftermarket filter. And the exhaust valve still working
File Type: zip dna_hotcam.zip (827 Bytes, 556 views)
It's better to burn out than to fade away
mace is offline
post #17 of 229 Old 09-10-2006, 05:53 PM
johnny napalm's Avatar
Send a message via MSN to johnny napalm
Here is my current map. Running full Akro and standard air filter on my 2006 ZX10
File Type: zip Pete's modded map1.zip (943 Bytes, 715 views)
johnny napalm is offline
post #18 of 229 Old 10-30-2006, 07:49 AM
fordfasterr's Avatar
Send a message via AIM to fordfasterr
Originally Posted by Hattori Hanzo
I'm also looking for a map for an 05 10R with Yoshi TRS slip-on stock air filter.
Do you have a TRE ?
If you do, then >> THIS <<< is a superior map.
I have the TRE and I am using this map on my bike and it doesn't even have the slipon yet.. Still runs awesome.
AIM = fordfaster - 2004 CBR 600RR
fordfasterr is offline
post #19 of 229 Old 11-05-2006, 09:48 PM
hongthaomurphy's Avatar
map
zx10r_map_from_k_n.zip
heres one just for the hell of it if someone wants to try it or critique it, that is if the attachment works.
murphy
hongthaomurphy is offline
post #20 of 229 Old 12-09-2006, 11:18 AM
Gone
pc map
hi guys, map for 04/05, racefit mega & bmc filter. i run this map on mine but use it with a racefit slash, works well. hope its of use for someone. cheers, tony
File Type: zip Racefitzx10rbmc.zip (799 Bytes, 756 views)
tony83 is offline
