Ninja ZX10 2008 5th and 6th gear issue - Page 4 - Kawasaki ZX-10R.net
 1Likes
post #31 of 39 Old 10-09-2017, 03:15 AM Thread Starter
Originally Posted by GreenOne View Post
Originally Posted by pedroguerra21 View Post
Curious thing... as it is a Selectivity issue today i tried to "cheat" the bike and installed a timing retard eliminator.. wich one of its main functions is to make bike "think" it is always on 4th ( no mod) 5th ( soft setting ) or 6th gear ( hard setting )...
Put it on 6th gear and guess what? Now it produces that issue in all gears...!
So i am definetelly sure this is due to a bad cartography in the ecu
Well, the important thing is do you have the problem when you put the tre to emulate 4th for all gears?
I was thinking about suggesting you get a tre for troubleshooting, but it is not free, so I did not.
By the way, I run a Gipro atre g2 myself in neutral all gears ("hard") setting to get around my closed loop issue.
When I get a woolich flash kit later I will check if the o2 sensor delete option actually keeps the ecu out of closed loop or just kills the FI light like the o2 eliminators. But for now the atre works perfect and gives a few other great advantages as well.(stp open sooner for part throttle, eliminates fuel cut on decel, and it does not measurable affect ram air compensation)
I apreciate your kind and attention .
Will be waiting for your news.
pedroguerra21 is offline
post #32 of 39 Old 10-09-2017, 03:17 AM Thread Starter
So here it is... a video showing the issue we've talking so far...
At this point i must refer some mods on the bike:
- Decat pipe;
- Kn air filter
- No exhaust valve
- Exhaust sensor eliminator ( ese by healtech)
- Akrapovic end can
By posting this video i am looking to find if someone has ever ocurred the same:
https://youtu.be/VkEnfuPlHHM
Just watched your video. It is 100% the same as the gen 2 behaves when the ecu is in closed loop and the o2 sensors don`t work as they should.. Just look at speed and throttle position in the log i posted. It is the same as your video....
Yes i understand your point but why only 5th and 6th gear? Shouldn't affect all the gears?
post #33 of 39 Old 10-09-2017, 03:20 AM Thread Starter
Just thinking...maybe someone deleted your o2 sensors by flash and it creates the same situation. I don`t know yet how this affects the ecu.
This is what i also believe... i am waiting for the new interface to arrive and see how it is
post #34 of 39 Old 10-09-2017, 10:03 AM
GreenOne's Avatar
No. Closed loop is only active in 5th and 6th for your bike as I have said. Se below for tps/rpm range.
Let us know how it goes with the troubleshooting.
I`m just in for the ride
GreenOne is online now
post #35 of 39 Old 10-09-2017, 11:13 AM Thread Starter
I have been talking this morning with healtech and 4th gear mode does not apply thr 4th gear ignition advance to all gears... instead of itit applies the Neutral ignition advance and other maps to all gears, wich depending on the map zone may the worth...
I will take the bike for a test today if i have the time and let you know...!
post #36 of 39 Old 10-15-2017, 09:02 AM Thread Starter
Back again with news....!
Entered the 4th gear map, wich is the neutral map, and guess what? SOLVED!
No more loss of power or "loop"...
Now will work on the neutral map to give her the hard kick she needs!
post #37 of 39 Old 10-15-2017, 05:14 PM
GreenOne's Avatar
Good news! Then it`s the closed loop issue.
You can just ride like this, but if I were you I would troubleshoot the problem starting with verifying o2 sensor function + wires, and if the ecu is flashed. There should be no reason for you to need the tre with the o2 sensors in place. Maybe a good "winter" project
post #38 of 39 Old 11-02-2017, 08:18 AM Thread Starter
So... here we go for the last part of the job.
Ecu reading and inspection ... and then some editing work and finally the flash!
post #39 of 39 Old 11-02-2017, 07:13 PM Thread Starter
For some reaso this O2 sensors were turned off in the ecu... maybe for damaged o2 sensors, or just because someone thought it would give her some more performance...
Well turned them on and installed again on bike... no errors so far... bike starts fine. I just couln not test it in the road because it is raining...
Meanwhile been working on the maps...
I'll keep in touch
