Gen 2: 2006-2007 New Turbo Project - Page 3 - Kawasaki ZX-10R.net
 42Likes
post #21 of 211 Old 01-19-2014, 09:13 PM Thread Starter
SpazOnaZX's Avatar
Looks pretty. Is that something you built or tested by chance? Construction material? How well does it work? I love sharing info. :)
It's always neat to see how things are mocked up VS how they look as a final piece... hopefully my stuff looks as pretty in the end as it is functional. I have an advantage in that I'm not trying to make money on this, it's just my spare time invested in learning how to do this on my own. It may take longer to get to the finished project, but I get to say that -I- made it, and I get to learn some good stuff in the process.
SpazOnaZX is offline
post #22 of 211 Old 01-19-2014, 09:18 PM Thread Starter
SpazOnaZX's Avatar
PS That #1 header in the picture collects way off the edge of the interior opening of that t-25 flange, and that runner especially is starting to collect parallel to the flange. We're trying to get the runners in this on to collect more perpendicular to the flange to promote better flow.... again, it's an experiment on a budget. I'm anxious to see how well it works.
post #23 of 211 Old 01-19-2014, 09:39 PM
None are mine. Def keep up posted with progress pics.
2016 GSX-S1000
08 10r Sold
Walter is offline
post #24 of 211 Old 01-23-2014, 07:45 AM Thread Starter
SpazOnaZX's Avatar
Well, it's in position. Now comes the fun part of working on all the aux plumbing before it goes off for coating. Going to have to alter the radiator fan bracket and lower mount a bit to clear the #4, but I think it's worth it to get the snail high enough to gravity drain... the shaft centerline is about 2" above oil level at the moment.......... hopefully that's good enough.
ID:	242249   Click image for larger version
post #25 of 211 Old 01-23-2014, 07:50 AM Thread Starter
SpazOnaZX's Avatar
How to keep flanges from cracking: Good root/fusion pass (BACK-PURGE!), clean, fill pass, clean, and a nice weave to finish it up. Found out the hard way before that single pass welding on the flanges supporting all that weight don't last all that long.
post #26 of 211 Old 01-23-2014, 08:24 AM
Capncalyx's Avatar
Originally Posted by SpazOnaZX View Post
How to keep flanges from cracking: Good root/fusion pass (BACK-PURGE!), clean, fill pass, clean, and a nice weave to finish it up. Found out the hard way before that single pass welding on the flanges supporting all that weight way don't last all that long.
Fucking nuts! Damn fine looking job there man. Looks like youve taken some time with that badboy. The tools you have access to is the stuff of most mens wet dreams. Keep up the good work.
Rock over London, Rock on Chicago!
We will all die but only a select few of us will ever truly live.
..known Internet Suspension Warrior....And Plinko Master!
Capncalyx is offline
post #27 of 211 Old 01-23-2014, 10:56 AM
Whats that merge look like on the inside?
2016 GSX-S1000
08 10r Sold
Walter is offline
post #28 of 211 Old 01-23-2014, 11:33 AM Thread Starter
SpazOnaZX's Avatar
Lots of work with porting bits is what it looks like. :) I'll snap some shots of it when it gets back from coating. But the backpurging keeps the weld looking pretty clean on the inside with good penetration. It's amazing the difference it makes.
post #29 of 211 Old 01-23-2014, 12:02 PM
Post Whore
-Op-'s Avatar
I wish I had half the talent and knowledge you do on this.
-Op- is offline
post #30 of 211 Old 01-23-2014, 02:26 PM Thread Starter
SpazOnaZX's Avatar
I'm not quite the welder that my friend is on steel, and he did the welding/fitting on this one. If I practice it weekly I can get there, but it really is a perishible skill. As far as the knowledge goes, READ BOOKS. ;) Then go break shit and scare the hell outta yourself trying to apply it, heheh. Seriously though, if you can ever find a tuner or builder in the game that will let you pay them for their time and to show/explain stuff to you, it's worth every penny. That's the spirit of DIY in a nutshell.... sometimes it's not the cheapest or fastest way to knowledge, but it sure is the most comprehensive. Don't let people discourage you with "Guy X does it better like this" or "That's ugly" kind of talk, just try to do a little better each time you do it, and learn from mistakes (I have a few really nice ashtrays, and I don't even smoke....). Probably one of my favorite quotes was from RB Racing: "Just because someone goes fast doesn't mean you should do whatever you think they did. This path assumes they knew what they were doing, which isn't necessarily the case. Take this path and you will be guaranteed second place.". Hell, their whole "Racing Secrets" page is right on point http://www.rbracing-rsr.com/secrets.htm
Tags
diy, fast, megasquirt, tuning, turbo
