Gen 2: 2006-2007 New Turbo Project - Page 21 - Kawasaki ZX-10R.net
 39Likes
post #201 of 208 Old 01-02-2018, 09:32 PM
thundercoupe9's Avatar
160psi is too much, you'll blow the the welds on the intake manifold like that hahahahaha.
thundercoupe9 is offline
post #202 of 208 Old 01-03-2018, 01:12 AM Thread Starter
SpazOnaZX's Avatar
Danger to manifold!
I'm still working out how much pressure I want to run... it is in a 'pull' set up, and it is near the end of the stroke. I'm using 3/8" line that's rated to 200psi... hopefully I can get it to do what it needs to do in the 120-140psi range. We'll see I suppose. :)
SpazOnaZX is offline
post #203 of 208 Old 01-03-2018, 08:29 AM
C3L1CA's Avatar
Nice on the air shifter! I pieced together my own setup too and have had the same setup for a long time on both my old r1 and my zx10. Hopefully it works out slick for you, I always had the damndest of time getting my nitrous to work right on my shifters for some reason, I had the same regulator and seemed to work 99% on the street dicking around but always missed a shift come race day when I needed it lol. Went back to air and it sucks having to fill it up after every run but it works every time. I fill my tank with air to about 150psi via a handheld craftsman compressor, that seems to be the sweet spot for my bike.
Now that you have the air shifter, you ever think about doing an auto shift too? I have a boost by smith shift light/autoshifter and its pretty slick. Guess LSR is different and probably have a bit more time in each gear but the autoshift is really nice in drag racing to hit the perfect shift everytime since the gears are so short with drag gearing.
200mph on a dirt road seems just nutty! So badass
SpazOnaZX likes this.
C3L1CA is offline
post #204 of 208 Old 01-03-2018, 10:32 AM Thread Starter
SpazOnaZX's Avatar
Thanks! I think I took some advice/parts from your set up too... it may or may not have been Medic's... I hit my head too much to remember everything, hehe.
Yea, with the non-pavement LSR stuff you have a lot more time, but shift points are still kind of a 'feel' thing for me based on traction... I try to run out the tach as far as I can in each gear before it really starts to spin badly.... the shift points aren't all that consistent for me yet.
Since I'm triggering the solenoid with the MS3Pro, I could easily have it 'auto-shift' at designated RPM breakpoints by gear. If this little bit of arm lets me hook it up in first gear I may just do that. I used to have a half-ass set-up like that with the old PC3... I'd just set the QS window minimum at my shift point and just preload the lever with my toe all the time. Not so great on the shift forks looking back on it now, but it was dead consistent and so easy to ride, especially out on road courses!
As far as the bottle goes, I'll play with it and report back. I'm going to use CO2, but I think the big trick is keeping liquid/slosh out of the regulator and solenoid. My bottle mounting should be straight up-and-down, so hopefully that will work. On the LSR Harleys we use the pingle set-up on 125ish PSI... and it works dead perfect... you just have to fill it up after every run. :) They use a bigger cylinder though, so I'm going to up my pressure a bit at first and see where it goes.
post #205 of 208 Old 01-03-2018, 06:58 PM
cooter's Avatar
Glad to see your still pushing the lsr stuff. I'm almost all healed up from surgery and waiting on my new bike to come in. Hopefully it'll be one worth taking out to the pavement events.
Don't lick the hand that wipes.
cooter is offline
post #206 of 208 Old 01-03-2018, 08:41 PM Thread Starter
SpazOnaZX's Avatar
Oh yea, it should be fun... especially if they do Springerville again this year. The high altitude and winds were just murdering the NA bikes.... Long'n'low S1000RR were trapping high 140's in the HALF mile up there.... need boost to play up at 9000 feet. :)
It sure would be awesome to catch an event with you this season.... shoot me a PM/text/whatever when you get that new beast. :)
post #207 of 208 Old 01-03-2018, 10:50 PM
cooter's Avatar
I'll let you know when I'm picking it up if you want. If you know anyone looking for a concours mines sitting at SV cycles for sale.
cooter is offline
post #208 of 208 Old 01-04-2018, 09:34 AM Thread Starter
SpazOnaZX's Avatar
Ha! I'm the only loon I know that would ride one that doesn't already own one, but I'll keep it in mind. Seeing the new H2 before you scoop it away would be cool... if I'm not at work I'd be down. :)
Tags
diy, fast, megasquirt, tuning, turbo
