Need new Gearing.. - Kawasaki ZX-10R.net
 2Likes
post #1 of 12 Old 03-08-2017, 08:02 PM Thread Starter
Jdog109socal's Avatar
Need new Gearing..
Ok I love my 2012 ZX10r but my biggest bitch with my bike is it really has no lower end gear power..Tired of other stock bikes pulling away from me and im full throttled.....Im not a big guy either. thinking of changing my sprockets out..
What do you all recommend for anew chain and sockets???????
Jdog
Jdog109socal is offline
post #2 of 12 Old 03-08-2017, 10:48 PM
turtle1000's Avatar
Jdog
Full exhaust and tune helps a lot too.
More cowbell
turtle1000 is offline
post #3 of 12 Old 03-09-2017, 09:19 AM
belkins's Avatar
Jdog
i just coverted to a 520 chain setup with a -1 in the front and +2 in the back and i must say it improved low end ALOT. Rifleman throttle insert will also get it there even faster than normal.
2013 Kawasaki Ninja ZX-10R
~Woolich ECU Flash/Log Box/AutoTune~Driven Block Off Plates~Woodcraft Frame sliders~Cox Radiator Guard~OEM Seat Cowl~Tinted Hotbodies Venom Windscreen~Lightech Chain Adjusters/Axle Sliders/Spools~Sato Rearsets/Race Hooks/Bar Ends/Reservoir Covers~Pazzo Shorty Levers~Engine Ice~Motodynamics Rear Turn Signals~Ohlins TTX MKII Rear Shock~R&G Case Savers~M4 Street Slayer Exhaust~Ohlins Race SCU~-1 +2 520 Driven Sprockets~520 DID Gold Chain~
belkins is offline
post #4 of 12 Old 03-09-2017, 09:45 AM
Capncalyx's Avatar
So, i have to ask - What stock bikes are pulling away from you?? And what mods do you have?
Rock over London, Rock on Chicago!
We will all die but only a select few of us will ever truly live.
..known Internet Suspension Warrior....And Plinko Master!
Capncalyx is offline
post #5 of 12 Old 03-09-2017, 03:12 PM Thread Starter
I have two buddies that ride 2010 bmw stock and they both pull away from me in lower gears . Bike is slow as shit till about 6k rpm then it bike takes off . And is way faster then both Bmw at 5 and 6th gear. I need more lower end since most track riding and street riding for that matter is run in 1,2,3, gears... anyways
My set up
2012 zx10r abs, ecu flashed , emissions removed except cat. Thats next to come off. Slip on can installed now.
Thanks for any info
Jdog
post #6 of 12 Old 03-10-2017, 09:10 AM
mpp12's Avatar
-1 on the front, only thing you want....
shorter than that lose top end
mpp12 is offline
post #7 of 12 Old 03-10-2017, 10:07 AM
Capncalyx's Avatar
Yep throw some gear at it. Kill the cat when you can. Can you shave any weight anywhere? Little things add up weight wise.
I know it sounds silly but if you can swing it get yerself a Anti-Gravity battery for instant weight savings and if you buy sprockets go for what is light with maybe some Ti nuts
post #8 of 12 Old 03-10-2017, 12:34 PM
sdiver68's Avatar
-1F (or +2 Rear) and Rifleman
Thank you to my racing sponsors Riders Discount and Alpha1 Vinylworks
sdiver68 is offline
post #9 of 12 Old 03-12-2017, 11:28 AM Thread Starter
Ok called Mike at riders discount and he hook it up for me..thanks all for the sugestion...
ridersdiscount and Victors like this.
post #10 of 12 Old 04-05-2017, 09:20 PM
ZX10RLanier's Avatar
Gen1 zx10r
K&N filter
Servo buddy
WRP slip on
45k +miles and counting
If you really want to go for it I'm running a 17-43 supersprox setup and it launches like crazy 1-3 wheelies all day and clutch ups in 5-6 ..
When I got the bike it had 18-39 gearing and it was slow on start but would run out the speedo then I went to 17-42 and it was good for all riding conditions now it's unpredictable if you come out the corner to hard it'll stand up if you top a hill it'll stand up ..you just have to tame it that's all..
It did have a pciii on it when got it and was not happy with it ,now two months have past since I took the pciii off and wow now i got to hold on it's like a new bike ..you can see it run on YouTube ( zx10rlanier)
ZX10RLanier is offline
