NEED HELP! GEN 4 throwing FI 16 code?!... - Kawasaki ZX-10R.net
post #1 of 17 Old 05-19-2014, 09:58 PM Thread Starter
troubleq45's Avatar
Hopefully someone can help me resolve this issue like yesterday! I have a 2011 zx10 thatgot the motor pulled and head and cams redone. Now it's throwing an 16 error code. All the traction control lights flash when u turn the key on and when the bike is started it won't rev over 6000 rpm and we can't figure out the issue?... Hopefully someone has experienced this that can give some insight. Thanks in advance
troubleq45 is offline
post #2 of 17 Old 05-19-2014, 10:01 PM
stangs10rnkc's Avatar
Send a message via AIM to stangs10rnkc Send a message via Yahoo to stangs10rnkc
intake air pressure sensor fault
stangs10rnkc is offline
post #3 of 17 Old 05-19-2014, 11:30 PM
Probably the connector on IAP sensor 2 (as Stangs mentioned) didn't get fully connected or there is something wrong with the sensor. Should be on the left hand side of the throttle bodies by the throttle cables. One plug.
Check and see if its connected and report back.
ZX10RArcher is offline
post #4 of 17 Old 05-20-2014, 06:34 AM Thread Starter
troubleq45's Avatar
Update, I checked it (on the side with throttle cables connected to throttle body )and it was connected and if I disconnected it I'd get a code 12 and 16. There's actually another sensor on the opposite side that's identical. We tried swapping it but got the same error code 16..
post #5 of 17 Old 05-20-2014, 06:47 AM
SkyDork's Avatar
The IAP is on top of the airbox up front.
#WordCrimes
SkyDork is offline
post #6 of 17 Old 05-20-2014, 07:40 AM
SkyDork's Avatar
^^^^Scratch that. The IAP #2 sensor in on the left side as Archer stated, just forward of the throttlebody near the throttle cable connections.
#WordCrimes
SkyDork is offline
post #7 of 17 Old 05-20-2014, 03:26 PM Thread Starter
troubleq45's Avatar
Swapped ECU's (other ecu also flashed? Swapped sensors and checked voltage which was also goof and I'm STILL getting the same code?... Lost
post #8 of 17 Old 05-20-2014, 03:31 PM
SkyDork's Avatar
Better start checking the wiring to make sure you don't have a broken one somewhere. That code is very specific for the fault it produces. And if you swapped sensors to a known good one, it's pointing to a possible wiring issue.
#WordCrimes
SkyDork is offline
post #9 of 17 Old 05-20-2014, 05:26 PM
SkyDork's Avatar
I would definitely be checking the ECU connectors for a bent pin as well. Especially if you've recently removed or swapped ECUs.
#WordCrimes
SkyDork is offline
post #10 of 17 Old 05-20-2014, 05:31 PM
If you've swapped out the sensors and ECU it points to a problem at the ECU or associated wiring.
Take a meter and start pinging the wires (steps in the manual) as well as looking for bent pins like Skydork said (on both sets of connectors; bike and ECU), as well as doing the ground and power supply checks for the ECU.
