NEED HELP! GEN 4 throwing FI 16 code?!... - Page 2 - Kawasaki ZX-10R.net
post #11 of 17 Old 05-20-2014, 05:41 PM
ZX-10R enthusiast
dudewhrsmybike's Avatar
Similar thing happened to me once. Turned out I crossed 2 connectors on my QS wire loom. If you have an ignition cut QS I would check to make sure the connectors are plugged in properly
Need some help with this one....
Sent from Motorcycle.com App
Strictly for my Ninjas
2011 ZX-10R ABS
17/41, Woolich Racing Tuned ECU and QS, Rifleman's 1/5th throttle insert, CL XBK5 pads, Yosh case sliders, Mivv Carbon w/ Ti Akra link
dudewhrsmybike is offline
post #12 of 17 Old 05-21-2014, 12:32 AM Thread Starter
troubleq45's Avatar
Thanks SkyDork that's exactly what the issue was a bad ecu connection. I sprayed electrical connection cleaner on it, disconnected the battery for a while and that was it.. after 2 ENTIRE DAYS and many calls later...lil.m -_-
troubleq45 is offline
post #13 of 17 Old 05-21-2014, 06:17 AM
dricked's Avatar
Any connector that gets undone gets dialectic grease on my bikes. Because I swapped the harness and ecu every single one is done on my bike. Nobody likes chasing electrical gremlins.
dricked is offline
post #14 of 17 Old 08-08-2017, 04:23 PM
did you fix the problemc cause i have the same one
Jose Manuel Robles is offline
post #15 of 17 Old 08-09-2017, 03:26 PM
SkyDork's Avatar
Hi there. Post #12 gives you the answer.
#WordCrimes
SkyDork is offline
post #16 of 17 Old 08-10-2017, 03:25 PM
thanks man
post #17 of 17 Old 08-12-2017, 02:33 PM
I just pulled of mythatgot the motor pulled and head and cams redone and the thing is i dont know how to fix the fault 16
ID:	403465   Click image for larger version
