Kit ECU Questions-Gear Ratio - Kawasaki ZX-10R.net
post #1 of 1 Old 04-17-2017, 11:30 AM Thread Starter
Hello,
Wondering what affects the Final Drive gear ratio has in respect to the mapping. Wondering if running the "0" map without changing the final drive ratio will have a negative affect?
It gives a warning if you have kit transmission "When using the kit transmission, it is necessary to change the gear ratio (reduction gear ratio). If the gear ratio is incorrect, the engine could burn out or break down."
Also for the Base Map's you have the F,M,L maps. When you look at them in the software they are all the same "0". But are they different? Text act's as if they are.
Thank You
-Randy
RANDYR41 is offline
