Gen 4: 2011-2015 interesting things at the dyno - Kawasaki ZX-10R.net
 1Likes
post #1 of 18 Old 06-24-2017, 06:16 PM Thread Starter
mpp12's Avatar
I was just with a friend tuning and we went to tune my bike
as for reference gen4s reflash, filter and slip on are 179 on that dyno
I have other moods, and was 188hp (thinner gasket and degree), then changed to gen5 headers, no change apparently.
then as a curiosity, tested my M map that is -1 degree on top from the F map, and the STV open slowly... now that Im checking they open 5% faster than F (stock map) and on top end stay open....
to my surprise the bike did 191 hp... and 1hp gain on all the rev range
tested my F map with just the -1 on ignition.. to my surprise the over rev was better and gained 1hp... 189...
then started opening the STVs slowly like the M map and 190 and better over revs.
I know Im spliting hairs...
but interesting the results
as for reference.... better than my bike is a race one 192hp on MR12 and a 1/4 mile one that makes 199 on mr12 also...
bmws16 do 183 there.
mpp12 is offline
post #2 of 18 Old 06-24-2017, 06:38 PM
Victors's Avatar
Kind of need more info... that data doesn't say much. Basically ypur bike likes -1 less overall advance?
Was there any gain from the headers at all?
I made 181 with flash, tune, Graves slip on, velocity stacks with a sprint filter. Literally went back a month later with zero changes and the bike made 175.. I'm at a complete loss with this bike.
2013 10R
2007 650R
2016 10R
Victors is offline
post #3 of 18 Old 06-24-2017, 06:39 PM Thread Starter
mpp12's Avatar
apparently no...
but a friend of mine will test on his 179hp gen4, the gen5 headers
mpp12 is offline
post #4 of 18 Old 06-24-2017, 06:42 PM
Victors's Avatar
Btw, what gasket did you use? What's all needed to do a gasket swap?
2013 10R
2007 650R
2016 10R
Victors is offline
post #5 of 18 Old 06-24-2017, 06:43 PM
Victors's Avatar
Originally Posted by mpp12 View Post
apparently no...
Be sure to post the results. I'm curious to see of anyone sees anything
2013 10R
2007 650R
2016 10R
Victors is offline
post #6 of 18 Old 06-24-2017, 06:44 PM Thread Starter
mpp12's Avatar
gasket swap, do a degree, and measure PTV clearance...
also use APE studs, my gasket went south 2 times, after the studs no more.
Victors likes this.
mpp12 is offline
post #7 of 18 Old 06-24-2017, 06:51 PM Thread Starter
mpp12's Avatar
Also.... stock STV map is not very restrictive.... even in M mode at 100% tps
mpp12 is offline
post #8 of 18 Old 06-24-2017, 09:34 PM
Who's dyno
bbsteinnewyork is offline
post #9 of 18 Old 06-26-2017, 06:57 AM
C3L1CA's Avatar
Nice results!
What did you you run from cam degree numbers and how did you check piston to valve clearance?
C3L1CA is offline
post #10 of 18 Old 06-26-2017, 08:57 AM Thread Starter
mpp12's Avatar
to check PTV clearance, you fallow the kit race manual, it explains it.
109.5-109
mpp12 is offline
