Gen 4: 2011-2015 i didnt bleed the coolant after a flush - Kawasaki ZX-10R.net
 1Likes
  • 1 Post By SkyDork
post #1 of 3 Old 08-13-2017, 09:49 PM Thread Starter
FastAsHellZX10's Avatar
Send a message via AIM to FastAsHellZX10
after flushing the coolant to change the mechanical seal, i filled the system back up till i topped off the radiator. put the cap back on. filled the overflow tank slightly above the f. put bike back together and after the last 4 rides it had sucked up to below the E. about 1/4 inch lower each ride. How much air did i leave in the system by not bleeding it? how many more rides before it displaces all the air with coolant. and was this a bad thing to do to my bike? can that amount of air in the system cause any damage to the motor or is it just simply not at 100% efficiancy and nothing to worry about . running temp has stayed between 155-165 so it hasn't overheated but could that be a bad thing that i didn't bleed it or no?
2015 30th anniversary ZX10R
Mods:Dark Tinted Windscreen, CarbonFiber TankPad, Akrapovic Full System, K&N Filter, Woolish Custom tune, 188.13 RWHP 81.46 TQ
FastAsHellZX10 is offline
post #2 of 3 Old 08-13-2017, 09:58 PM
Victors's Avatar
Youre fine.. just top it off.
If the overflow never actually emptied then you were never low in the system.
2013 10R
2007 650R
2016 10R
Victors is offline
post #3 of 3 Old 08-14-2017, 10:04 AM
SkyDork's Avatar
Air in the system causes the coolant to boil if heated above 212 degrees. That's BAD news! But it's typical that some air is never really expelled until you heat the motor up a couple of rides and let the system equalize and push the air out. So just top it off and continue riding it like normal.
Originally Posted by Victors
You're fine
Victors likes this.
#WordCrimes
SkyDork is offline
