Gen 4: 2011-2015 How To: Fit larger ZX10R ABS battery to non ABS ZX10R - Kawasaki ZX-10R.net
post #1 of 1 Old 03-13-2017, 09:32 PM Thread Starter
Exclamation How To: Fit larger ZX10R ABS battery to non ABS ZX10R
1) Remove your puny little battery
2) Get your Dremel
3) Cut this little plastic divider out of the battery box (careful not to cut any wires)
4) Now you can fit a YTZ10S battery or equivalent size battery (preferably Lithium) for much higher CCAs (Cold Cranking Amps), and your bike will no longer start lazily and make you worry that it won't fire up.
10Arghh is offline
